Reload this Page >
Kolm 135 install in CARF Mustang
Old 11-17-2016, 02:08 PM
  #526
DrScoles
My Feedback: (18)
DrScoles's Avatar
Originally Posted by flygono
Here are some pictures of how I hard installed the engine only supporting the back.
She proved very strong in the air, so much so that after crashing braking the fuselage and left wing in halve the front fuselage including fire wall remained intact, definitely stronger than it needs to be.
I am building a second one and started a thread on rcscalebuilder.com lots more pictures there, will do similar intallation
LOL, mine did same thing, I smoked the wings and took the tail off right behind the canopy... front remained unscathed. Grafted another tail onto it. So you didn't support the front of the motor? Is that a 100 or 135?
ID:	2190305   Click image for larger version
Old 11-17-2016, 02:13 PM
  #527
flygono
My Feedback: (9)
DrScoles
Mine is kolm il 135cc.
nice repair job I did think of doing something similar but without an intact fuse and without a jig there is a chance that i spend months repairing to when flying time comes and proves to have wrong incidences
Old 11-17-2016, 02:21 PM
  #528
DrScoles
My Feedback: (18)
DrScoles's Avatar
My buddy had two complete kits, this was an old fiber classics kit... so I got the wings and fuse from him, worked out well. I didn't have a jig, just eyeballed, and it was going from the foam core to straight fiberglass.... kinda scary, but worked out well. It has flown. :-)
Old 11-17-2016, 02:24 PM
  #529
flygono
My Feedback: (9)
well done Drscoles
Old 11-17-2016, 10:25 PM
  #530
Ixtrim
Ixtrim's Avatar
i agree. you need really hard rubbers. otherwise the 2zylinder will shake a lot.
also you cowling needs to be seperated in to halfs. with installed baffling you will not be able to bring the cowling on and off.
looks good. go on!
My voodoo project is back on the bench. fews weeks left on the "skin" befor i can start with engine istallation.
Old 11-18-2016, 11:00 AM
  #531
banjbob1
Thanks for the pics and the info guys.
Good you got it flying Dr Scoles,you told me about breaking the prop before,would have been scary alright.
Yes Tom i have the cooling all worked out involving an EDF, more progress has been made since these pictures were taken,i was deliberating over the Kolm install but i'll just use the rear mount now.
The main reason i want to do away with the front mount is because i can't get the engine out with the mount on the front.
Flygono,what thickness ply did you use for the firewall?
Old 11-19-2016, 12:16 PM
  #532
luckymacy
The prop extension came. It's about an inch longer than what came with the engine and will obviously go a long way towards a better fitting installation and final CG.
Old 11-19-2016, 12:22 PM
  #533
luckymacy
What they call an ISB box also arrived. It takes a 3 or 4 cell lipo in and powers the ignition, starter motor and the fuel pump. Operates off of just on switch on the transmitter. Hard to see in the wrapping but there's 3 leds to help you figure out what's going on.
Old 11-20-2016, 04:43 PM
  #534
luckymacy
So the jist of the box is a single three or four cell lipo feeds the starter motor, the fuel pump and ignition system. The ISB box also replaces an ignition kill switch. Think of the isb as your fuel pump controller because that's the receiver channel you program to operate the pump based on throttle position.
the 4 cell was needed to start the 135. Too much compression for the 3 cell. Maybe way later after the engine is broken in a 3 cell might work.
Old 11-21-2016, 09:01 AM
  #535
banjbob1
Luckymacy
Where did you order that box,that's just what i need,i see you're using the same rx's as me,great aren't they.
Old 11-21-2016, 09:09 AM
  #536
banjbob1
Jamie
I plan to use the same cooling idea,did this work for you?
I take it the fan sucks the cool air through the baffle and heads then pushes hot air out through the radiators?
Rob
Old 11-21-2016, 09:46 AM
  #537
luckymacy
Originally Posted by banjbob1
Luckymacy
Thomas Gass, aka LXTRIM, helped me order the box. Last time I was on the company's website I couldn't find it.
http://www.cs-scale-concepts.de/index.php
Old 11-22-2016, 10:24 PM
  #538
Ixtrim
Ixtrim's Avatar
Right, if you want to have one, you can contact me! hope they will put it soon in their online shop. meanwhile, you can order it per mail :-)
Old 11-24-2016, 04:51 AM
  #539
banjbob1
Thanks,i will need to order one in Jan/Feb time,i contact you.
Old 11-25-2016, 05:42 AM
  #540
pacoflyer
My Feedback: (23)
Rob,
Could you give me more info on the cooling fan you mentioned?
Looking to avoid a cooling issue in a P-51 project I have planned for this winter.
paul
Old 11-29-2016, 07:22 AM
  #541
banjbob1
pacoflyer
I haven't started the installation yet and was looking for some info: from anybody who has used the EDF method of cooling.
I'll post pics when i start it.
Old 12-10-2016, 06:07 AM
  #542
Hello82
great that you got her fliying again dr scioles!!! love these babies......
my mustangs keep getting bigger...H9, TF, Ziroli, Carf and now Chad Veich!
got my Kolm 230 semi installed in the Chad Veich all wood P51 (112") and working on duct work from all balsa, and baffling soon...I might try an EDF in middle of fuse if need be via back big scoop....but will try cowl chin air in first. Hope the ducts are big enough??? used BVM heat shield on hot air out to prevent warping balsa, over resin first.
any recommondations on best edf units?
so gotz was saying rubber mounts up front only? but you are saying no? where do you get them anyhow?
ID:	2192985   Click image for larger version
ID:	2192986   Click image for larger version
ID:	2192987   Click image for larger version
ID:	2192988   Click image for larger version
ID:	2192989   Click image for larger version
ID:	2192994   Click image for larger version
ID:	2192995   Click image for larger version
Old 12-10-2016, 11:39 AM
  #543
DrScoles
My Feedback: (18)
DrScoles's Avatar
Wow, quite a build! Is that true 1/4 scale? I made the spacers with my lathe. Wish I had the experience/skills/time to attempt a scratch build. If the front of the fuse is strong enough, I would consider metal mounts, although I never tried a mix of the two. My rubber mount experience scarred me... LOL But Gotz and Thomas have way more experience with this stuff.
Old 12-10-2016, 01:54 PM
  #544
Hello82
ya true 1/4 scale...make the math that much easier! but still a ton of (fun) work ... ya gotz said metal spacers in back and rubber up front...
so you are flying the rebuild now you said, yes? any video? are you building another? I might do another Carf 51 down the road but with a KOLM also
Old 12-17-2016, 10:25 AM
  #545
Hello82
Originally Posted by jamie_wram
Sorry--the pics failed to load on previous post.
looks good Jamie....so that is blowing air onto engine to cool,...... or just helping to suck hot air out through a fuse duct, and cooling engine basically starting from another real air in vent?
thanks
Matt
Old 12-30-2016, 08:38 PM
  #546
DrScoles
My Feedback: (18)
DrScoles's Avatar
Got three flights in today. Awesome! This plane was broken in two on the maiden a year ago. I grafted a tail and put new wings on it. Here is a video
https://www.youtube.com/watch?v=dGfgH_L0gMM
Old 12-31-2016, 05:49 AM
  #547
Hello82
super! what a great way to end the year!! she looks and flys great!
any more pictures of your final engine install and baffling etc?
any issues on the flight?
happy new year
Matt
Old 12-31-2016, 05:52 AM
  #548
luckymacy
Excellent. Excellent. Excellent.
When you think of it, show the true power to weight ratio of the set up by taking her straight up on take off and see if she can accelerate straight up or just pulls nice and steady like a tractor. My son has a possible C-17 pilot slot to McChord AFB and is mulling it over so I'll have to show him the foul weather gear you're sporting. Everyone in Washington dresses like they are ready for the next rain event that's going to occur at any moment! :-)
Old 12-31-2016, 08:02 AM
  #549
DrScoles
My Feedback: (18)
DrScoles's Avatar
Foul weather gear? That's our daily attire!!! LOL. I'm not outside in sub 40 degree weather much. That's all my snowboarding clothes. Lucky, if your son likes rain, come on out!
Old 12-31-2016, 08:05 AM
  #550
DrScoles
My Feedback: (18)
DrScoles's Avatar
Matt, if you scroll through this thread, I put lots of detailed pics of the install. I put telemetry on the two heads. Temps were 120 and 100 pretty much the whole flight. I know it's too rich. It was also 40. Does that mean it will run 30 degrees hotter at 70??? Don't know. I know 270 is the danger zone, so I am way far away. I flew one flight last summer and it never went past 170. Gonna lean 1/8 turn for next time out.
