Reload this Page >
GROUP BUILD - Top Flite Giant Scale F4U Corsair
Old 07-05-2010, 11:13 PM
  #7226
mrrandyman
Default RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Hi Folks, I started the Corsair build a couple days ago and other than having missing parts it has gone together pretty well. My question is this. How is everyone figuring out where thier panel lines and such should go. Since it isn't to scale I can't find a decent decimal number to use.
Thank you in advance.
Oh and if you guy's want I can post all my pictures of the build.
Old 07-05-2010, 11:46 PM
  #7227
Shaun Evans
Shaun Evans's Avatar
Hi,
Yes, please. Post your pics!
Old 07-06-2010, 06:33 AM
  #7228
rt3232
Hi Mrrandyman
The pnl lines as shown on the back of the manual is about the best I have found, and as you know this bird was mostly spot welded so a double row at each line is realy all you need to give the effect, and for size I would check in overon the 1/6 scale build under RC SCALE,
And Please do post pic;s of your build
Cheers Bob T
Corsair Brotherhood #5
Old 07-06-2010, 09:56 AM
  #7229
wulf190
My Feedback: (19)
wulf190's Avatar
Have drummed up some motivation to get my plane airborne finally. Am due to return from the sunny gulf coast this weekend and will see if I can get her up. Vacation is great but it sure does bite into a guys airplane season. Will post some shots of the guts of my bird when I go througgh the punch list that still exists (a short one at least). Will see if the 2.4 system and a moved throttle servo and switch get rid of my interference problem
Old 07-06-2010, 11:47 AM
  #7230
mrrandyman
Hi folks
Here are the first set of pictures of my current build. I hope they will help someone. Please let me know if you see any problems as I go along.
I'm thinking of leaving the sheeting to the last untill I have all the radio gear, hatches and such located.
Randyman
ID:	1464001   Click image for larger version
ID:	1464002   Click image for larger version
ID:	1464003   Click image for larger version
ID:	1464004   Click image for larger version
ID:	1464005   Click image for larger version
ID:	1464006   Click image for larger version
ID:	1464007   Click image for larger version
ID:	1464009   Click image for larger version
ID:	1464010   Click image for larger version
ID:	1464011   Click image for larger version
Old 07-06-2010, 11:49 AM
  #7231
mrrandyman
Here is the next set.
ID:	1464013   Click image for larger version
ID:	1464014   Click image for larger version
ID:	1464015   Click image for larger version
ID:	1464016   Click image for larger version
ID:	1464017   Click image for larger version
ID:	1464018   Click image for larger version
ID:	1464019   Click image for larger version
ID:	1464021   Click image for larger version
ID:	1464022   Click image for larger version
ID:	1464023   Click image for larger version
Old 07-06-2010, 11:51 AM
  #7232
mrrandyman
Here are some more.
ID:	1464025   Click image for larger version
ID:	1464026   Click image for larger version
ID:	1464027   Click image for larger version
ID:	1464028   Click image for larger version
ID:	1464029   Click image for larger version
ID:	1464030   Click image for larger version
ID:	1464031   Click image for larger version
ID:	1464033   Click image for larger version
ID:	1464034   Click image for larger version
ID:	1464035   Click image for larger version
Old 07-06-2010, 11:54 AM
  #7233
mrrandyman
And some more. this about 3 days work. Now I have to wait on the missing parts to arrive from Top Flite.
ID:	1464043   Click image for larger version
ID:	1464044   Click image for larger version
ID:	1464045   Click image for larger version
ID:	1464046   Click image for larger version
ID:	1464047   Click image for larger version
ID:	1464048   Click image for larger version
ID:	1464049   Click image for larger version
Old 07-06-2010, 12:26 PM
  #7234
Shaun Evans
Hi,
That's only 3 day's work? Wow. That's great. Looks like you're doing a good job, too.
Unfortunately, it seems like the advent of ARF's and their domination of the hobby seems to have chased off all the real builders. I hate to see threads pop up entitled "Blah Blah Cheap Totally Prefabbed ARF BUILD Thread" as though that's actually building. Some guys at least have the honesty to call them "Assembly" threads! The worst thing is that those threads seem to have more following (and the assembler seems to rate more accolades) than actual build threads. I know it's because there are fewer and fewer builders building kits...and a higher likelihood of someone wanting to see someone else working on the plane they're working on; but it still bums me out. So BRAVO for doing an actual BUILD!!
Old 07-06-2010, 01:04 PM
  #7235
mrrandyman
Thank you for the support. I'm a hardcore builder. Always have been and always will.If they want to call them selves builders that's fine with me. I can tell the difference at the field. It is a shame though that the actual builders are dwindling but it seems to me that people are in such a hurry now and days. No one can stand still for a minute to really look at things.
As long as there are kits to build and a supply of balsa I'll keep carving away.
Old 07-06-2010, 03:40 PM
  #7236
NCIS
Relax,
There will always be plans and wood. Thats all you need if you can't get a kit. Laser cutters aren't going anywhere in the next 20 years so if you have a plan of a Warbird you want to build whether it be per the plan size or blown up they can help. Pat at Laser Cut USA is the best kit cutter out there.
Nice job so far,
Barry
Canopy Rails for Warbirds/Owner
www.canopyrailsforwarbirds.com
Old 07-06-2010, 05:40 PM
  #7237
rt3232
Mrrandyman
Looks great [sm=thumbs_up.gif] I would sugest putting 1 pc of sheeting down each side to pravent twisting if you pull it from the board, and punch holes in every thing you can aft of the C/G area to keep from having to add nose wieght. back about page 50 or so I posted some pic of the tailwheel structure and if I do another I would do more
Hope this helps
Cheers Bob T
Old 07-06-2010, 05:45 PM
  #7238
mrrandyman
Yes thank you for the info. I will be sure to lighten up the back structure and I will add some sheeting. I sure don't care for the rudder setup they show on the plans. It seems pretty sloppy in movement but I'm not sure what else a person could use without adding more weight.
Old 07-06-2010, 06:39 PM
  #7239
nauticom
Hello:
I'm new to your great build site. Been following for some time, but this is my first post here.
I have a scale question for someone out their.
I am building a Zorili GS Corsair 93" WS, etc. On the full scale bird, the right wing had a spoiler added after early manufacturing, around 42 or 43 to the -1A and all subsequent builds. This spoiler was added to assist in eliminating left wing tip stalling on landing.
I have put my guess as to size of this on my build. I saw a full scale -1D at Oshkosh a couple years ago and was about 6" in width( works out to be about 1 1/4 " on model).
My problem is the pice I built seems way to large depth wise. I guessed it was about 3" deep at the wing leading edge, which translated to around 1/2" on the build. Just looks way to big.
Questiondoes anyone know the depth on that thing as measured from the leading edge of a full scale -1A so I can scale this thing more close to what is should be. I guessed it was 3" deep, which scaled out to 1/2".
I think Corsair Jock had done some scale measurements a few years ago.
Much thanks much for your help.
PS
Love the Corsair build world. Sign me up
Also sorry if this is only a TFGS build
Bob Masterson
nauticom
Old 07-06-2010, 08:26 PM
  #7240
wulf190
My Feedback: (19)
wulf190's Avatar
Bob
Looks like you are figuring out some of the scale inaccuracies of either drawings or wing chord or both maybe. Stuff like this always pops up in a scale build it seems when you start laying out panel lines hatches, exhaust fittings, etc. Whatever size you end up making them, might depend a lot on what you think looks best after checking some documents and measures. It is a good question you pose, and it's impressive you are detailing it out to that degree.
Happy building...I wish I would have built the ziroli in the end...as that gull wing is a total space hog in the shop, I don't think I really save much room in storage than a ziroli would take up.
Old 07-06-2010, 08:45 PM
  #7241
ctflyboy
CORSAIR BROTHERHOOD (UPDATED 7/07/2010)
NAME SCREEN NAME NUMBER ASSIGNED
George Ctflyboy 1
Devens 2
Gibbs Ncis 3
David Tomcat 4
Bob RT 5
Winston Cimara 6
Charlie Foxfoto 7
Cliff Cliff 600 8
Tim TIM (Deceased) 9 (RETIRED NUMBER)
Dave D Bronk 10
Scott Scotty C 11
Mike Wulf 190 12
B Bowen 13
R Schaffer 14
M Callahan 15
Randy Bossman 16
Quinn Corsairkidd 17
Scott Sbleile 18
Ron Flytoolow 19
Phil Fili 20
R Monty 1 21
Mike Corsairbrotherhood 22
(NUMBERS 23 & 24) not used
Kelly Thunderbolt 25
Sam DaddySam 26
(Numbers 27 thru 34) not used
Mike Picard 1 35
Howie Texasskydiver 36
Leonard 555 41
Nick Frisconick 44
Nick M3guy100 48
Scott Fly 2xs 49
Gary M Gary M 50
Don Airboss45 51
George GTC 52
Radek Radek M 53
Jim JazzRC 54
Jack JSCogin 55
Robert Acerc 56
Nchrome 57
Henry FTMustang65 58
Duane Aceisback 59
Bob nauticom 60
mrrandyman 61
Read more: http://www.rcuniverse.com/forum/m_31...#ixzz0sxNvcLz5
Old 07-06-2010, 09:00 PM
  #7242
ctflyboy
ALERT NEW BROTHER ALERT
LETS ALL WELCOME " Bob Masterson or Nauticom" TO THE BROTHERHOOD
Bob YOUR NUMBER WILL BE 60
W E L C O M E TO THE
BROTHERHOOD
GEORGE
CORSAIR Brotherhood 1
Read more: http://www.rcuniverse.com/forum/m_31...#ixzz0sxRDxCKY
Old 07-06-2010, 09:25 PM
  #7243
ctflyboy
Wulf 190 (Mike)
Glad to see you in here,
Hope all goes well on the maiden
George
Corsair Brotherhood # 1
Old 07-07-2010, 08:23 AM
  #7244
nauticom
Thanks guys.
I'm still about a year away from a maidenwork gets in the way. Thanks much will follow along for an impressive ride.
BobM
Old 07-07-2010, 02:51 PM
  #7245
mrrandyman
If you folks want I can do a youtube on this build also if your all interested.
I'm sure it will be like watching paint dry but perhaps it will help someone.
Randyman
Old 07-07-2010, 03:19 PM
  #7246
rt3232
Welcome Bob M [sm=thumbs_up.gif]
Randy man for my part just post hear and watching grass grow is not a bad thing
cheers Biob T
Old 07-07-2010, 08:39 PM
  #7247
ctflyboy
LETS ALL WELCOME "mrrandyman" TO THE BROTHERHOOD
YOUR NUMBER WILL BE 61
BROTHERHOOD
GEORGE
Read more: http://www.rcuniverse.com/forum/m_31...#ixzz0t3CoKEfx
Old 07-07-2010, 08:44 PM
  #7248
ctflyboy
BRINGING IT FORWARD GUYS FOR THE UPDATE
George
CORSAIR Brotherhood # 1
Old 07-07-2010, 08:45 PM
  #7249
ctflyboy
George Ctflyboy 1
Devens 2
Gibbs Ncis 3
David Tomcat 4
Bob RT 5
Winston Cimara 6
Charlie Foxfoto 7
Cliff Cliff 600 8
Dave D Bronk 10
Scott Scotty C 11
Mike Wulf 190 12
B Bowen 13
R Schaffer 14
M Callahan 15
Randy Bossman 16
Scott Sbleile 18
Ron Flytoolow 19
Phil Fili 20
R Monty 1 21
Sam DaddySam 26
Mike Picard 1 35
Leonard 555 41
Nick Frisconick 44
Nick M3guy100 48
Scott Fly 2xs 49
Gary M Gary M 50
Don Airboss45 51
George GTC 52
Radek Radek M 53
Jim JazzRC 54
Jack JSCogin 55
Robert Acerc 56
Nchrome 57
Duane Aceisback 59
Bob nauticom 60
mrrandyman 61
Read more: http://www.rcuniverse.com/forum/m_31...#ixzz0t3EhNHLb
Old 07-07-2010, 09:28 PM
  #7250
rt3232
Hay Randy Man
Welcome to the group [sm=thumbs_up.gif]
Cheers Bob t
corsair Brotherhood #5
