B-29 SUPERFORTRESS BUILD
#226
Following your build, very impressive. On my twin engine aircraft I run a centralized fuel tank in the fuselage with a common ignition battery for all the engines fed through a IBEC. This frees up your nacelles. I have two birds configured this way and it works great. The fuel lines are connected to the fuse via MPI check connectors so the wing can be removed. Not sure if it will work for you but just a idea to throw out. Jerry.
#228
My Feedback: (95)
JB Thanks, I'm always open to suggestions and ideas. I thought about the centralized tank before but it won't work out in my case.
BC It will take some serious time and commitment to build one of these. I goes fast at first and looks simple enough to build, but then it gets envolved. This plane has been the ultimate challenge for me so far. I'll be happy when it's finally completed.
#230
My Feedback: (95)
Well the plane is just about at the painting stage but it has been so damned cold up here I haven't had a chance to get to it. I usually paint out in the garage, but with the temps averaging at -10 to 10 week after week I can't get it warmed up enough. I guess I could post some small detailed stuff. I was hoping to have it painted before winter set in 'cause there will be a lot of set up and detail work to do after that.
#231
NY
I know what you mean, NY has been cold to. I would definitely love to see what where you are up to on it. I do have one question for you though. How did you "break" apart the wing to make it able to transport in your trailer, thats a big wing. coming from someone who doesnt have a whole lot of experience with big birds with multiple engines on the wings how are you going to make it so you can disconnect the motors? I assume you are going to have 1 servo per motor? will you have to disconnect 4 wires or are you going to use some sort of Y harness?
Sorry for the stupid newbie question. Im trying to get back up and building a 65" c-130 hercules that got destroyed in my last move, Looks like I have to start all over.
#232
My Feedback: (95)
The outer wing panels come off. This one is modified though from the original plan so the out board engines are with the outer panels. This shortens the center section enough so that it stays attached to the fuse and I can keep the plane on its gear to roll in and out of the trailer. See post 123 for more details. I'll have to disconnect 3 leads at each panel. The throttle, flap and aileron. Each engine will have it own ignition battery. The engines all have their own servo and will plug into a match box first for fine tuning adjustment. The flaps will be split ( 2 pc ) because of the removable outer panels so there will be a servo for each flap section. Those will also run into a match box for fine adjustment. I'll be using a 12 channel power safe RX also to plug all this stuff into.
No such thing as stupid questions here. It's all apart of learning.
#234
FL
Very nice build!! Looks like I need to order one. I just finished my 138" wingspan B-17. Awaiting the first week of March for her maiden.
Here is my thread. B-17
I would of like to of seen a build like this over at RCSB. I'm going to book mark it by adding it to my thread for safe keeping!! I really need to see your flap stuff too!! I have modified fowler. They can be seen operating on YouTube.
Below is my taxi test. A full gammit of videos on the plane at YouTube.
Simply EXCELLENT!! Please visit us at RCSB!! I will continue to follow.
Speed
https://www.youtube.com/watch?v=1JokToYYFE8
Speed
#235
My Feedback: (95)
Very nice B-17 Speed! Always wanted to build one of those. (if I ever finish this one)
There is a similar B-29 build thread on RCSB. Go to Don Smith plans and look for "Old man and a B-29." I didn't post my build there because that one was already in progress.
Good luck with the maiden. They look spectacular in the air!
#236
My Feedback: (7)
Speedracer:
You are such a tease!!
Point of fact: it would have rocked my world if you had flown off that tree-lined avenue. No room for error coming back!
For those of you who are now gnashing teeth to see the 1/9 fly, here's my maiden from 3 years ago.
http://www.youtube.com/watch?v=Stur27qHh7c
Yikes! 3 years ago!
No flights since: I have been training on a 120" Wescraft to get ready for this season's "second maiden," and many flights to follow, I hope.
mt
Yikes! 3 years ago!
mt
#237
My Feedback: (7)
For builders' inspiration, here's the maiden of my buddy Frank's 14-ft B-29 last spring.
Frank is the best and most prolific builder I personally know, although I'm sure Warbirdman would give him a run for the money.
http://www.youtube.com/watch?feature...&v=pyfoSDkKPFw
DLE-20's
Frank spent the rest of last year Bogartin' all the event trophies in the region
He did have some concerns after about flight #15 with stress cracks around the inboard nacelles, which he reinforced somehow
Frank's not much of a thread follower or poster, so if you want details, go through me
mt
DLE-20's
mt
#238
FL
Speedracer:
Yikes! 3 years ago!
mt
Yikes! 3 years ago!
mt
I don't want to clog this thread with B-17 stuff so I'm going to email. I need more info on your bird. Looking at the video you chopped your power at the end of the runway and her dropped like a rock! Nice catch!!.
Back on topic.....
I contacted Larry at Precision Cut Kits. Its a no go for now on the B-29. It might change with a bit more research. I was looking forward to it. Looks like I will be building a Albatross from BUSA instead.
Warbird Man, Did you see the rivets on my B-17? They make the plane my friend. They are made by Chad Veich Models. I highly recommend them!!!
Speed
#239
My Feedback: (95)
Very impressive speed! That must of taken some serious time. I don't know if I'll be doing rivets on mine anymore. I had planned on covering with flight metal also but now I just want to get it done and off the bench. (got too many other warbirds waiting to get built)
Bummer about Precision not cutting B-29 kits. I suppose there is not a big demand for them. I see kits and parts for the B-29 every so often in the RCU classifieds.
#240
FL
No, that's the beauty of it. They are laser cut vinyl dots 0.03 in size placed in rows of 200. Peel and stick then paint. Very fun!! I have a full section in my thread on them.
No they still cut them. We just couldn't come to a agreement for now. Maybe later. ( I'm pretty, scratch that, I'm VERY demanding) Buying my last kit at Wingspan was a nightmare so I want a perfect purchase this time. All the parts as promised when promised. I cant find enough people to tell me their purchase at PCK was good. But there is no end to the people who support BUSA. So I will go there this time.
Speed
Speed
#241
My Feedback: (95)
I quickly scrolled threw your build thread on your B-17 project and I must say, I have never seen such a thorough, well laid out, detailed build thread- ever. It was hard too tell from the video just how much detail you put into it. Excellent job on both the plane and build thread!!!
( ya make me sick)
Just kidding, your a master at your craft!
( ya make me sick)
#242
My Feedback: (95)
Anyway, I didn't like idea of having exposed switches, fuel dots, and vent tubes sticking out of the nacelles and there wasn't a good place to mount them without interfering with the fuel tank inside, so I came up with some hatches that resemble the full scale access panels to hide them in. The fuel vent will come out in the dummy exhaust pipe on the opposite side.
#244
FL
RCSB is packed full of "scale enablers" a bunch of sick puppies! I had no intentions of any of that. You just get hooked over there.
Very nice detail on the hatches. I will be copying those.
Keep at it!
Speed
Keep at it!
Speed
#248
Hi Warbird, I just read the full thread. Have you kick the building of the B29 up again? I am planning to buy a kit from precision cut and would like to know if you can give me any hints? Its been what 6 years now for such a difficult challenge but on the other hand this plane is a builder's dream! Can you post an update or some pics of how the project is? I would really appreciate it and would also like to congratulate you on this endevour. Regards!
#249
My Feedback: (95)
Hello Cheriegate. I am still working on it when I find the time. Much has changed in life since I started this project and I never intended for it to take this long. I am in the painting process. I have some parts finished. I'm currently working on the outer wing panels. A lot of work sanding out the imperfections and low spots.
#250
My Feedback: (23)
