Reload this Page >
Jemco Focke Wulf 190D-9
Old 07-25-2013, 07:27 PM
chistech
Default RE: Jemco Focke Wulf 190D-9
I currently have the following Jemco kits NIB to build: P51, Corsair, AT-6, P47, Hellcat, and Zero. I also have a PT-19 with the fuse done, waiting for some time to finish. Of course I also have the following Royal/Marutaka 40 size kits: Raiden, Rufe, and a custom laser cut full duplicate Rufe. Then I have Tettra 40 size kits: Shinden Kai and Cessna 182. A TF Cessna 182,a Aero Tech Sea Fury, and a Pilot Lake Buccaneer. All warbird kits will get retracts, most likely electrics. Just realized, have a Davis P47 almost all built up with flaps and full retracts/tail wheel.
Man, I got to get building.
Old 11-20-2013, 07:02 PM
motoman326
Definitely going with retracts since I have a set I think will drop right in (famous last words). Have to clear off the bench and dive in. I will keep you posted....
Old 12-17-2013, 09:51 AM
motoman326
OK I took the plunge and started the FW-190. Hopefulley the pictures will post correctly
Old 12-17-2013, 09:52 AM
motoman326
And some more
ID:	1948320   Click image for larger version
ID:	1948321   Click image for larger version
Old 12-17-2013, 09:59 AM
motoman326
The plans are only "slightly" faded
Name:	photo plans.JPG
Old 12-17-2013, 10:12 PM
  #31
Ram-bro
My Feedback: (101)
makes me wanna pull mine out the attic. It would be neat to have a contest where all the planes/kits are pre 1990 vintage
Old 12-18-2013, 03:06 AM
  #32
dionysusbacchus
My Feedback: (25)
dionysusbacchus's Avatar
I had one of these in 1980, even made the local news paper. I painted it with a brush and it had a K&B .40. Good times!
Luke
I look just like this now!
ID:	1948595   Click image for larger version
ID:	1948596   Click image for larger version
Old 12-18-2013, 01:28 PM
  #33
F4u5
My Feedback: (81)
Luke
Indeed, it is always fun to think back to the times and building of these old kits in the late 70's/early 80's...usually on a door core laying on my mom and dad's chest freeezer, out in the garage. I had a Jemco Corsair.....loved it.
Even back then Luke was knocking them out of the park on those finishes. Good luck with the FW190 motoman
JQ
Old 02-10-2014, 08:08 PM
  #34
motoman326
Wing is 100% complete. Just need to finish the fuselage.
Old 03-05-2014, 08:24 AM
  #35
motoman326
OK The FW-190D is completed.
Let me know what you think.
I haven't weighed it since my scale seems to have vanished but it feels light.
I will let you know how the maiden goes.
Final specs:
OS 40 LA engine
Fixed gear
Futaba servos
Spektrun 6200 receiver
JR 9503 Transmitter
Old 03-05-2014, 12:50 PM
  #36
dionysusbacchus
My Feedback: (25)
I don't want to be rude man, but did you use sandpaper? Why the flat block leading edge and wingtips? I think it will fly like crap, but good luck anyway.
Old 03-05-2014, 06:32 PM
  #37
motoman326
That's how it was on the plans, so that's how I built it.
Old 03-05-2014, 07:33 PM
  #38
dionysusbacchus
My Feedback: (25)
OK, I'm here to tell you that you made a rookie mistake, but it was a big one that could really hurt the performance and it looks really bad.
Looking at the leading edge on the plan I can kind of see how you wrongly interpreted it, what you didn't see is that the plans show the wing at the center section and it does have a SLIGHT flat spot that you would sand onto the leading edge after you sanded it into an airfoil shape so that it sits right in the fuselage. What you would do when building a scale plane is look at the full scale subject, Google images and you will see that the full scale does not have a block leading edge or wingtips. Jim designed this plane with a very accurate outline, you'll just have to trust me that you are wrong and he is not.
Like I said I built mine in HS, here are some other pictures where you can clearly see the wingtips and leading edge. All I can say to you is try and learn from this and don't stop building, we all had to start somewhere and we all make mistakes. As you gain experience those mistakes will hopefully be less and less and certainly far less obvious than this! I want a flight report, I am very curious as to how this will fly.
Name:	JEMCO FW-190-D9 Blueprints-xx.jpg
ID:	1975476   Click image for larger version
ID:	1975483   Click image for larger version
Old 03-05-2014, 09:32 PM
  #39
motoman326
Well I can tell you your plans look a LOT better than mine. That may have also contributed to the way I built it.
I've asked around and some people think it shouldn't be TOO much of a problem. Fingers crossed, I'll maiden it the next decent weekend.....
Thanks for the honesty.
John
ID:	1975496   Click image for larger version
Old 03-06-2014, 03:52 AM
  #40
deatonbt
The Jemco FW 190 that I had as a kid and a few years ago flew great, but it would drop fast without tip stalling when the throttle was chopped to idle; drop really fast. It is easy to catch by applying some throttle and then chopping it a few feet above the ground and then flair. I think that the plane will have to be landed at high speed if it does fly with a flat leading edge. It looks like film covering is used on the wing. It would only take about three hours to pull the film, sand the leading edges round, taper the tips on the wing panels, and apply new covering. It is a cheap investment after putting so much work into the plane.
Brian
Old 03-06-2014, 08:50 AM
  #41
motoman326
Brian,
I plan on flying it as is.....
if it flies really bad (and it doesn't get destroyed) I plan on pulling the covering..adding a curved leading edge and recover....
John
Old 03-23-2014, 08:53 PM
  #42
motoman326
Maiden flight of the FW-190
Flew great...
Here's the video
https://www.youtube.com/watch?v=KaerTfyCEio
Weighed in at 5 lbs 6 oz
Old 03-24-2014, 02:45 AM
  #43
deatonbt
I didn't call that quite correctly. It flies well. Congratulations.
- Brian
Old 03-25-2014, 07:41 AM
  #44
motoman326
Thanks Brian, I am very pleased with it!!!
Plus it was a beautiful day so that was a bonus!
I'm still tempted to put a rounded leading edge on it to see how the flying characteristics change.
I will post the changes if / when I make them.
Old 03-25-2014, 09:23 AM
  #45
Warbird AL
My Feedback: (10)
Looks nice and thanks for posting the vid, I enjoy seeing others' planes flying!
Old 04-15-2014, 10:34 PM
  #46
bigtim
My Feedback: (13)
I just picked up one of these and was considering what to do about the retract situation I have never built a foam core wing before but was thinking a I beam set up for the mounts any tips out there for this.
thinking the med sized electrics would work for this size, I have a OS 46 laying around that seems like a good fit for this size plane
I like the looks of this kit and I got a good deal on it so I jumped from what I have seen it looks to be a fairly quick building but I def want to put some retracts on it
Old 04-17-2014, 12:26 PM
  #47
paladin
My Feedback: (9)
i would put ply in the foam core like ribs then sand them to the foam surface then mount a 1/4 in ply plate between them and it worked great. non of this was lt. ply
Joe
Old 11-28-2018, 04:17 PM
  #48
jeanlabbe
Default jemco folcke wulf 190D
Hi everyone,
I am currently building this type of plane and unfortunately I broke the canopy. Does anybody know where I could find another one? Or is anybody would like to sell me this part of his plane?
Old 11-29-2018, 05:41 AM
  #49
paladin
My Feedback: (9)
if you r unable to get a new one, look at the one u have. is it a single crack? you can crack stop it (drill a hole at the end of the crack) then but glue the peace's with formula 560 and a brace on the back side overlapping the crack by .125 in on both sides also attached with formula 560. then fill and sand out the outer surface and paint it. some times the crack stop and patch does not look that bad and I leave it that way.
https://www.towerhobbies.com/cgi-bin...&I=LXCX70&P=ML
brian taylor planes sells a canopy for their 60 in ws that may work.
FOCKE-WULF FW190 A-4 | Brian Taylor | RC Model | Scale Plan
Joe
Old 12-23-2018, 10:17 AM
  #50
Luft-Gangster
Originally Posted by jeanlabbe
Hi everyone,
Dug through my pile of kits and found that I have the means to help!
Plan is simple. I will make a plug with the one in my kit so I can make another. Wont be until after Christmas. Lots of things going on with my kids and grand kids.
Let me know if your still looking for one.
