Top Flite P-47D Thunderbolt ARF .60-.91: Building & Mods
#402
RE: Top Flite P-47D Thunderbolt ARF .60-.91: Building & Mods
Smchale, is that a static prop? where did you get that? looks great!
I found a APC 14.5x11x4 and a couple 15.5x12x4. Now I need to see if the YS120 I have can spin that, if not maybe the DLE20!
#403
My Feedback: (32)
Sean, your P-47 looks awesome.
Kirk
Kirk
ORIGINAL: smchale
I just finished mine, using Ron's as inspiration with basically the same setup. I agree the hatch was a pain to cut free. I used a pin from the inside to cut it close, then cleanep up the edges afterwards. Also needed to recover around the edges after filling them. Here's a couple pics of mine.
#404
My Feedback: (67)
ORIGINAL: Gutaaaooo
Years ago when I built the kit version Top Flite offered a static prop (as well as a full bodied pilot). Sadly, both were discontinued shortly afterwards.
#405
Hello all
I just picked up the TF P-47 that use to belong to "Planenuttz" here in this forum in a trade for my Cermark F-16 Propjet. I hope to upgrade my "NEW" bird with the pylons and drop tanks from FirepowerRC soon. Can't wait.
I currently own the Hangar 9 P-47 1.50, and the H9 P-47 .60 size. I really like the looks of the TF P-47 because of the flaps and drab covering. I really like the way P-47's fly. Nice and easy!!
Photos & video to come soon.
P.S Planenuttz really did a nice job on the building of my P-47. I feel lucky to have this nice plane.
Jim Stratton
Greenville, SC
Jim Stratton
Greenville, SC
#406
[8D]What a beautiful job[X(][X(][X(], congratulations buddy..... I couldn´t resist and showed that beauty on my spanish build-blog.
http://www.acro3d.com/public/phpbb3/...p=66996#p66996
Cheers.
Manuel.
Cheers.
Manuel.
#407
My Feedback: (22)
I already kissed up to Sean on the other site..lol
Great job Sean, you always make it look easy and do a great job... love the sound system as well.
you guys are all doing great stuff to this plane...love it
Hey Josh,
I did just like Sean said... I took some long T-Pins and pushed them through the seam line of the hatch from the inside.. in all four corners. I then worked my way all the way around the hatch sticking the pin through everywhere I could. I used my exacto saw and knife and carefully cut it out.. with out cuting the the locating pins on the back. You also have to knock out two small dowls on the front of the hatch.
I cut the covering back about an inch, sanded it all smooth, added a little filler hear and there...
ordered a roll of flat olive drab and covered back into the hatch area on the fues and recovered the hatch.... that was it....
Sorry to hear you had a mishap but that happens in this hobby, you just move along and you will get it right next time
good luck and have fun! thats what this is all about
Ron
ron101, hi my name is josh and i was wondering if you could help me the battery hatch i have the same plane and i tried to do what you did to your p-47 but i kinda mess up a bit. i am ordering an other plane to try again at the hatch. would it possible if you can tell me the dimensions of what i need to cut out( like length, and width) and more or less of you did. thank you. btw awesome job on you p-47 it looks great. -josh
Ron
#408
My Feedback: (67)
Josh,
I think these are the saw blades Ron is referencing. I find them very handy for multiple uses. In fact I have a couple old xacto handles so I don't have to keep swapping blades.
http://www.micromark.com/7-PIECE-11-...-SET,6567.html
#409
[8D]Maybe this step by step how to will help, .....
http://www.acro3d.com/public/phpbb3/...start=120:eek:
Manuel.
Manuel.
#410
thank ron for the tip. question i like the wingpylons were did you get them or was that home made. ?
-josh
-josh
#411
My Feedback: (22)
thank ron for the tip. question i like the wing pylons were did you get them or was that home made. ?
-josh
-josh
it's the best bomb and pylon kit I have seen.. very detailed instruction
After I had mine finished I gave him some pictures and he put me on his wedsite which is cool
don't forget to order the bombs and drop tanks too... very fun to drop bombs! man I have to get out and fly
here is a link:
http://www.firepowerrc.com/top_flite_p-47_pylons.htm
#412
My Feedback: (67)
Manuel, thanks for the comps...and the inspiration with your fantastic build. Can't wait to see it all to gether.
Josh, Ron is right the firepower r/c stuff is nice. I typically cringe when needing to work with vacuumformed parts, but these were nice and thick and easy to deal with. Can't wait to bomb up our field!
The pylons are easier to install during the build before the wing is joined. Have fun with them!
#413
Hey guys, just got my LADO retracs/oleos for this puppy, and the OLEOs are great for this bird, they don't have that angled scisor thing, so thre is no need to cut the wing for a good fit (see pictures). The only thing is I got the 170mm long OLEOs, and the 160mm would be a perfect fit, (thery have oleos from 100mm to 210mm, with 10mm increments) now I have to mod it to that end, should be easy enough. http://www.lado-tech.net/proddetail.php?prod=RS3333LEGS
By the way, these are my fist LADO full retracts, and not just a retrofited robart. They look amazing, and much stronger then the robarts, as it's almos solid, but still very light. I took mine apart to see it's guts, but forgot to take pictures, sorry. The machining is amazing!
EDIT: Reduced the size of the pictures. I don't know why they where so big before, I guess I thought RCU would do it on its own. Sorry!
#415
My Feedback: (14)
I am getting close to finishing my P-47. I put an OS 75AX inverted in the plane with a JTEC incowl muffler. I was hoping to conceal the muffler within the cowl but with the cowl being norrow at the bottom I had to cut some holes for the muffler tubes to exit the cowl. It does not look to bad but not as nice as I was hoping. I have also installed CJ retracts and a on-boad glow system Hoping to maiden the bird this coming Saturday
#416
ORIGINAL: Gutaaaooo
TX.
Manolo.
#417
Hey Manolo,
The oleos have a 5mm pin that is secured to the retract, I don't know the the size of the TF strut, and now I'm away from home, so I can't check that for you, sorry.
By the way, did anyone find a better wheel that fits in the wheel wells? I just hate the foam wheels
#419
My Feedback: (67)
ORIGINAL: JeffH
smchale, now that is a great looking P-47. I am not crazy about P-47s simply due to them being overdone everywhere, but yours looks great!
Here's a video clip from the P47 Maiden flight:
http://www.youtube.com/watch?v=em9j6WNJyG8
And one with the bomb drop and sound on:
http://www.youtube.com/watch?v=EEH7QjrElnk
The weather didn't help, nor did the Turn Pike noise...but you can see it flys at least. :-)
#420
Hey Smchale, that's a great looking bird and flying you got there!
Is that the firepowerrc's bomb drop you got there?
I ordered mine also, but I'm waiting for Rich to send me.
How do you like them? Are they easy to set up, assemble etc? Some pictures would be great!
Again, congrats on the great looking bird!
#421
My Feedback: (90)
Congrats on another successful maiden. I would congradulate you on your nice landing, but those of us who have flown this plane know that to be typical. NOT taking away from your flying skills, just a compliment to the ARF.
#422
My Feedback: (67)
ORIGINAL: Gutaaaooo
ORIGINAL: CorsairJock
#423
My Feedback: (67)
A few people have PM'd me for some more details on the model.
Here's a summary of some of the details: Hacker A50-16L motor, CC ESC, 2x 4S 5000mAh 45C ThunderPower lipos in series for 8S, APC 17x12E prop, Truturn spinner, Model Solutions of Canada Sound card and 2x 4" 4ohm speakers, 2x 3s 910 mAh Electrifly lipos in series for 6S power on the sound, 1700 mAh nicad rx pack, CJM retracts, Robart Struts, Sullivan wheels, Firepower R/C dropable bombs and plyons, Aces of Iron pilot bust, Testors MM paint, promark nomenclature, getstencils vinyl graphics for large lettering, klasskote satin clear dulled down. Top Flite static prop. AUW 14.5 lbs.
#424
My Feedback: (10)
IL
Those P-47's are looking good! I hope to add some pics of mine flying here soon. Man, Top Flite really hit a home run with these newer ARFs. You can't ask for a better ARF, and they know what customers really want. Sometimes when I compare TF ARFs to others I just laugh- most companies can't even get the wheel and strut size close. What's with the tiny wheels on most ARFs, huh? Can't they even look at a picture of the full size craft? Drives me crazy. Meanwhile I have to get back to work... I have got behind in my production for several reasons and am trying to catch back up.
#425
SO it's gonna be a high of 38 Deg today with no wind. Packin for the field and was trying to decide what birds to take.......YUp, My P-47 after watching and reading here
God I love this plane
