Reload this Page >
ESM 82" Hawker Hurricane
Old 05-16-2011, 04:58 AM
  #176
NoFlaps
My Feedback: (131)
Default RE: ESM 82
Old erikki,
regarding venting hot air out, try creating baffles to help direct the flow of air.
I'll get mine back out this week and see about mocking something up for you .
I'll post some pics as soon as I can.
Old 06-06-2011, 12:50 PM
  #177
Destroyer of Airplanes
My Feedback: (25)
Destroyer of Airplanes's Avatar
Default RE: ESM 82
Well I finally got to fly her. The conditions were not ideal much too gusty but, you can't wait forever for smooth air. The airplane was balanced as per the book,, but I found her to be tail heavy. It was really too rough to do anything much of anything. I never even got the gear up. She was rock steady. the landing was fast with no flaps. Looking forward to our first calm day.
Paul
ID:	1619835   Click image for larger version
Old 06-06-2011, 12:57 PM
  #178
NoFlaps
My Feedback: (131)
Default RE: ESM 82
looks great Destroyer of Airplanes !
Hopefully you can get someone to video her as well.
Thanks for posting !
Old 06-21-2011, 09:47 PM
  #179
PSJDBF
Default RE: ESM 82
I had to make a turning approach to avoid the sun & land my Hurricane on Monday...looked quite scale in the end as I know they use to have a low nose & banking approach on the real deal for vision over the nose.
Short vid of the landing, my big wheels require a little more air pressure for the next run I think, I also added a little more weight to the nose & she was a lot more stable on the approach & flair (she was a little pitch sensitive before ).
http://www.youtube.com/watch?v=Sjy94e7o52c
Old 06-21-2011, 10:04 PM
  #180
balistc1000
balistc1000's Avatar
Default RE: ESM 82
Very nice!
Old 06-22-2011, 01:22 AM
  #181
Brad330l
Brad330l's Avatar
Default RE: ESM 82
ORIGINAL: PSJDBF
Cool mate,, well and truly there now.
Brad
Old 06-22-2011, 02:21 PM
  #182
Neo gold
Neo gold's Avatar
Default RE: ESM 82
Steff...that engine sounds awesome!!...i'm building one right now & at a total loss as to what engine to fit!..i need a tidy in-cowl fittment....can you put up some close shots of the cowl removed & one with it on please?...would be a great help to me, also what flight imes are we looking @ with that 200ti & the supplied 550cc tank?...close up shots would be great.
Many thanks
Marc
ORIGINAL: PSJDBF
Old 06-23-2011, 03:42 AM
  #183
PSJDBF
Default RE: ESM 82
Hi Marc, I cant wipe the smile off my face every time I fly the Hurricane, I think the 200Ti has the perfect sound for a warbird, doesn't sound like a merlin maybe but has a distinct growl to it.
I think I have posted these pic's before but may have been on a different thread, these are all I have at the moment as the Hurricane is stored at a mates place but it will give you an idea.
The 200Ti is not fully cowled the front cylinder sticks out a fair bit however I stuffed up with the first install of the engine so the rear cylinder could be fully covered however it does help keep it cool.
As far as the fuel tank goes I fitted a 750cc tank which required a little opening up of the formers BUT not alot & I would average about 8- 10 minutes in the air at the moment depending on throttle management but the 200ti has been supprisingly fuel efficient & I am landing with half a tank still left [X(].
Look forward to seeing the progress on your build.
Cheers Steffan.
ID:	1626612   Click image for larger version
ID:	1626613   Click image for larger version
ID:	1626614   Click image for larger version
ID:	1626615   Click image for larger version
ID:	1626616   Click image for larger version
Old 06-23-2011, 08:16 AM
  #184
NoFlaps
My Feedback: (131)
Default RE: ESM 82
It does sound awesome...I play the flyby's over and over just to hear it.
Old 06-23-2011, 11:38 AM
  #185
Neo gold
Neo gold's Avatar
Default RE: ESM 82
Thankyou Steff, that looks very tidy....can you please show me your exhaust arrangement?...& i bet the extra weight helped with balancing the model yes?...did you need to add much more?.
Thanks for all your help.
Old 06-24-2011, 02:08 AM
  #186
PSJDBF
Default RE: ESM 82
I used a set of Saito flexible exhaust's that I've shaped to exit at the bottom of the cowl secured to the fire wall, dont have any good pictures of it yet but will grab the Hurricane next Tuesday & take some of the set up.
I had to add a lot of weight to the front to balance it due to the fact that I did a full cockpit build with a full bodied pilot so had to move the rudder & elevator Servos back into the rear of the fuse.
If you weren't to do the cockpit I'd imagine it would balance with out much if any extra balast with the 200Ti.
Will get back to you next week with more pics.
Cheers Steff.
Old 06-28-2011, 05:17 PM
  #187
PSJDBF
Default RE: ESM 82
Pictures as promised .
ID:	1629024   Click image for larger version
ID:	1629025   Click image for larger version
ID:	1629026   Click image for larger version
ID:	1629027   Click image for larger version
ID:	1629028   Click image for larger version
ID:	1629029   Click image for larger version
ID:	1629030   Click image for larger version
ID:	1629032   Click image for larger version
ID:	1629033   Click image for larger version
ID:	1629034   Click image for larger version
Old 06-29-2011, 02:24 PM
  #188
My Feedback: (25)
Default RE: ESM 82
Setffan,
Your cockpit is stunning. One of the best I have ever seen.
Paul
Old 07-02-2011, 04:23 AM
  #189
PSJDBF
Default RE: ESM 82
Thanks Paul I get carried away sometimes !. Cant help myself.
Old 07-02-2011, 06:17 AM
  #190
Kostas1
Kostas1's Avatar
Default RE: ESM 82
Awesome....
Old 07-03-2011, 02:58 PM
  #191
Neo gold
Neo gold's Avatar
Default RE: ESM 82
Thankyou for those pics steff...looks a top job you have done there, unfortunatley i cannot afford that engine & so decided to go petrol.
I would be paying £22.50 for a gallon of nitro...MT propower 16%.
I'll miss that scale sound!.
Old 07-14-2011, 05:52 PM
  #192
CSpierings
My Feedback: (29)
Default RE: ESM 82
Anyone have access to Dick's article in Highflight about building this model?
Old 08-15-2011, 10:27 PM
  #193
Tomek007
Default RE: ESM 82
Hey, I was looking at getting this model since I see only good things on it. On the "Troy Built Models" website it states that a glow 1.60 engine should do the trick also. Now my question is, would my o.s 1.60 2 stroke glow engine be able to handle this airplane?
Old 08-16-2011, 12:37 AM
  #194
flycatch
My Feedback: (26)
Default RE: ESM 82
Don't use a 1.6 OS. It does not have enought power for the overall weight of the model once balanced. If you want to stay with glow go for a Saito 1.8 FS. You would be adding additional weight and less dead weight to balance. The Saito is more than sufficient and it sounds great.
Old 08-18-2011, 03:42 AM
  #195
dkm
dkm's Avatar
Default RE: ESM 82
Has any one built the 82" Hurricane with a OS FS-200 ?
Old 08-26-2011, 07:56 AM
  #196
kenair
My Feedback: (10)
kenair's Avatar
Default RE: ESM 82
dgiatr - Can you post some pics on your engine installation and with the cowl on. I plan to get this arf and will definately use a gas engine, probably the DLE 30 or the MVVS / EVO 35.
Anyone else got gas engine installs, would love to read your posts.
thanks -ken kalynuk, winnipeg canada
Old 09-09-2011, 02:48 AM
  #197
dgiatr
dgiatr's Avatar
Default RE: ESM 82
HI Kenair, unfortunately i lost my plane a month ago due to elevator pull-pull rope cut!!!!my mistake was that i used one rope NOT DOUBLE rope for each side of the pull-pull system!! i am building a new one right now but i am only in the beginnig ( i have just finished my cmpro p-40!! 73' span ). i will use the same engine dle 30cc because i think that its suitable for this plane. i dont think its overkill because its a big plane with a huge thick airfoil! but i must say that you have to cut much of the cowl if you use dle 30 custom exhuast. for that purpose i got a pits muffler from sds hobby (pits muffler for 26-30cc gas engine ) and now i hope i will cut less. yuo can also get bisson pits muffler for zenoah engines ( it fits to dle 30cc) and you can also look at this on you tube > watch the cowl cut..nice job!
Old 09-09-2011, 03:03 AM
  #198
kenair
My Feedback: (10)
kenair's Avatar
Default RE: ESM 82
Hi, sorry to hear about your Hurricane, thanks for the video link and the tip in the pitts muffler. I think the DLE 30 is probably my choice.
cheers - ken
the video link is at [link]http://www.youtube.com/watch?v=QuvhsNTXRLo[/link]
Old 09-25-2011, 11:47 PM
  #199
dgiatr
dgiatr's Avatar
Default RE: ESM 82
Hi Kenair!, i have just finished and maiden my second hurricane and everything its ok! i have to say that i didnt used the pits muffler that i told you before because i had to cut much of the cowling that way, i used dle 30cc stock-custom muffler instead! which is the most compact muffler with less cowling cut!! for that engine. i balanced my plane at 11 cm (quite nose heavy i know!!) but it flies fantastc that way and i thinking of not changing it.
Old 09-26-2011, 03:00 AM
  #200
kenair
My Feedback: (10)
kenair's Avatar
Default RE: ESM 82
Supernews, post some pics when you can.
thanks!
