Knowledge Quiz for Warbird wiz
#355
RE: Knowledge Quiz for Warbird wiz
Here we go:
-Early P-47 thunderbolts were re-fitted with other types of propellers during WWII, the standard 12β Curtiss was commonly replaced by the 13β paddle blade Curtiss prop. Beside this the Hamilton prop or the 13β asymmetric Curtiss prop was also fitted on the later versions of the thunderbolt.
A) What is the main reason for this?
-Here is an example of the paddle bladed Curtiss prop on a P-47D-10-RE.
B) At the base of the propeller blades there is an easily distinguishable different shape. How are those named and what is the reason for this or what role are those shapes playing?
[img][/img]
[img][/img]
#358
maesteromodels, you got question A) right, indeed to improve performance, especially the rate of climb.
Now for B) looking for the typical name for those special shape on the propeller blades ?
Now glasscock is close on B), de-icing boots, but it played an aerodynamic role also.
Looking for the typical name of those shape
#361
My Feedback: (221)
ORIGINAL: MerlinII
Here we go:
[img][/img]
Here we go:
[img][/img]
The Hamilton Standard Hydromatic prop was cuffless but had the wide blades that came to be referred to as 'paddle' blades. It was the largest diameter used at 13' 1 7/8".
#362
well we can only have one winner ;-) here and based on your 2 correct answers its your turn maestromodels,
thanks jharkin also and ram3500-rcu for your very accurate info
merlinII
merlinII
#364
My Feedback: (8)
The prop cuffs also helped in cooling the engine...
According to my 2nd phase (engines ) teacher at Riverside School of Aeronautics, Mr. Hamm, who was a P-47 crew chief in England during the war.
He was a very interesting guy, who joined the Army Air Corps in 1933, and started his career working on B-9's and B-10's.
By the time the war was over, he was working on some of the first operational P-80's...
#365
My Feedback: (221)
ORIGINAL: proptop
#366
My Feedback: (8)
ORIGINAL: ram3500-RCU
I thought this would be a reason as well, but the Hamilton Standard cuffless props were used starting on many of the D models. I would have thought if this was an issue, only cuffed props would have been used by then.
ORIGINAL: proptop
True, the Hamilton Standard props didn't have them. I'm just recalling what he told us in class...the later model '47's had improved engines.
There were lots of changes being made, pretty much a constant evolution...development of new engines, cooling baffle design, slight cowl modifications too.
Cuffs were also on B-50's props used on the 4360's. (one of my flying buddies was on a B-50 from 1950 to '52 ) Cooling was only part of the reason for using them. I believe the early P-47 props were Curtiss electric props? So were the B-50's...so perhaps it was a Curtiss design thing that wasn't required when using the H-S props? Unfortunately Mr. Hamm has long since passed, so I can't ask him.
The cuffs helped move more air right near the hub.
#371
My Feedback: (221)
ORIGINAL: on_your_six
Because the generator was on the left engine... no engine, no electrical power.
I'll try and do better next time.
Guess your up.
#373
FL
I think they had 3 wheels for each main strut and the tires were filled with nitrogen and the tires impregnated with aluminum to with stand the heat
No SR-71 was ever shot down from an enemy missle.
#374
So right you are... I saw one last Saturday... great bird, leakiest wings ever on the ground... fuel was hard to burn and required two hemi engines on a start cart.... the hemi engines were blown after 10 starts...
So continue on Mastermodels... what is your question?
ORIGINAL: masteromodels
#375
FL
This is my last question. Can anyone name the plane the germans used for the first time glider-borne troops were used in a military operation.and who designed it. since this is my last turn I thought I would make it a little harder.
