Reload this Page >
Knowledge Quiz for Warbird wiz
Old 03-18-2016, 04:27 AM
  #12851
Top_Gunn
Not the Twin Mustang, but that answer inspires today's clue.
Looking for an aircraft.
1. It was intended as a successor to a plane that became very well known during its wartime service.
2. It was inferior in one important respect to the plane it was supposed to replace, and so only a few hundred were built and the only one left is in a museum.
3. It was larger, heavier, better armed, and had a higher service ceiling than the airplane it was meant to succeed. But it was inferior to it in one way (a way in which the Twin Mustang out-performed its predecessor).
Old 03-18-2016, 04:49 PM
  #12852
Hydro Junkie
Hydro Junkie's Avatar
SB2C Helldiver
Old 03-18-2016, 05:18 PM
  #12853
Top_Gunn
Not the Helldiver, although that is a good match for many of the clues. New clue in the morning.
Old 03-19-2016, 04:18 AM
  #12854
Top_Gunn
Today's clue:
4. It served from soon after the beginning of the war for which it was designed until the end of that war, but mostly in a non-combat role, rather than the role for which it had been intended.
Old 03-20-2016, 05:00 AM
  #12855
Top_Gunn
Today's clue:
5. Designed and built by the same company that produced the plane that this one was meant to succeed.
Old 03-20-2016, 08:04 AM
  #12856
Hydro Junkie
P-63 Kingcobra
Old 03-20-2016, 08:13 AM
  #12857
Top_Gunn
Not the P-63, Hydro, though I'm beginning to suspect you of reading my mind, as I've done earlier quizzes about both the Helldiver and the Kingcobra. This plane wasn't built in anything approaching the numbers those were, however, and most of them were scrapped soon after the war in which they were used ended.Here's another clue:
6. Four engines, which was twice as many as the plane it was supposed to (but didn't) replace.
Old 03-20-2016, 09:59 AM
  #12858
Hydro Junkie
PB2Y Coronado
Had the gunnery of a B-24(less belly turret), could handle two torpedoes externally or 1000lbs of bombs in wingroot bomb bays, four engines but a much shorter range than the PBY 5 and 5A Catalinas
Old 03-20-2016, 11:43 AM
  #12859
Top_Gunn
And the Coronado it is! A very attractive plane, if you like huge flying boats, as I do. Used mostly as a transport, and a pretty good plane except for range. You're up.
Old 03-20-2016, 12:16 PM
  #12860
Hydro Junkie
When you said twice as many engines as the what it replaced and said four engines, it really limited the options of what plane you were talking about. Using your clues, here's where I went thought wise:
1. It was intended as a successor to a plane that became very well known during its wartime service. To many to narrow down to one plane
2. It was inferior in one important respect to the plane it was supposed to replace, and so only a few hundred were built and the only one left is in a museum. Again, too many options but went with the Twin Mustang as the single seat versions were much more maneuverable
3. It was larger, heavier, better armed, and had a higher service ceiling than the airplane it was meant to succeed. But it was inferior to it in one way (a way in which the Twin Mustang out-performed its predecessor). This one said, shorter ranged, which the Helldiver was as compared to the Dauntless. It also carried almost twice the ordinance load of the Dauntless
4. It served from soon after the beginning of the war for which it was designed until the end of that war, but mostly in a non-combat role, rather than the role for which it had been intended. This threw me for a loop, no idea at this point
5. Designed and built by the same company that produced the plane that this one was meant to succeed. This one took out many of the aircraft manufacturers since most were heavily engaged in manufacturing existing designs. It led me to Curtis(P-40 reworks and variants), Consolidated, Lockhead and Bell. Was thinking Chain Lightning and King Cobra at this point
6. Four engines, which was twice as many as the plane it was supposed to (but didn't) replace. My last post said it all
Old 03-20-2016, 12:22 PM
  #12861
Hydro Junkie
Okay, time for my first clue. Unlike my quiz's in the past, I'm sticking with one aircraft this time. And, the first clue is:
1) This plane was designed to replace an earlier aircraft
Good Luck
Old 03-20-2016, 05:32 PM
  #12862
uncljoe
My Feedback: (8)
uncljoe's Avatar
Douglas Skyraider old naval Id. AD (attack Douglas) later (1963) AE
Semper Fi
Old 03-20-2016, 07:40 PM
  #12863
Hydro Junkie
Nope, not a Skyraider. Actually that was the plane in my last quiz. Time for another clue:
2) This plane had superior firepower when compared to it's predecessor
Old 03-21-2016, 10:22 AM
  #12864
Hydro Junkie
And time for another clue:
3) This plane used a smaller crew than other comparable aircraft
Old 03-21-2016, 04:17 PM
  #12865
JohnnyS
P-47 Thunderbolt?
Old 03-21-2016, 10:41 PM
  #12866
Hydro Junkie
Not the T-Bolt and that means it's time for another clue:
4) This plane's service life was longer than any similar aircraft of the era
Old 03-22-2016, 04:57 PM
  #12867
Hydro Junkie
No guesses means it's time for another clue:
5) This plane was considered "Light" even though it could carry more weight than some called "Heavy"
That one might give it away
Old 03-23-2016, 07:49 AM
  #12868
uncljoe
My Feedback: (8)
uncljoe's Avatar
Douglas B 26 Invader
Old 03-23-2016, 05:59 PM
  #12869
Hydro Junkie
I thought so. Here's a rundown on the clues:
1) This plane was designed to replace an earlier aircraft The plane to be replaced was the Douglas A-20 Havoc
2) This plane had superior firepower when compared to it's predecessor The A-26 could be fitted with up to 22 50 caliber machine guns including three mounted in each wing and gun pods mounted below as compared to the A-20's 13
3) This plane used a smaller crew than other comparable aircraft Unlike the A-20 needing four people or the B-25 needing five to operate the plane, the A-26 only needed three
4) This plane's service life was longer than any similar aircraft of the era This plane was used in an attack role of some sort from June 23, 1944 until 1972
5) This plane was considered "Light" even though it could carry more weight than some called "Heavy" The A-26 could carry up to 4000 lbs of bombs internally and up to 8000 lbs more externally. This 12,000 lb load was larger than the B-17G's 9600 lb and almost equal to the B-24J's 12,800 lb load
One more thing, the A-26 was build by Douglas, not North American. NA produced the legendary B-25 Mitchell bomber.
Uncljoe, You're up
Old 03-24-2016, 02:30 PM
  #12870
uncljoe
My Feedback: (8)
uncljoe's Avatar
If anyone has a question fire away, Sorry about that the B 26 was built by DOUGLAS brain cramp
Clue 5 was the give away .... FWIW seems Douglas always built a plane that could haul a lot of weapons SBD, AD1 Skyraider, B 26 Invader
Joe
Old 03-25-2016, 05:33 AM
  #12871
Ernie P.
Joe
All; uncljoe has declared the floor open. If you have a question ready, fire away. First come, etc.,. Thanks; Ernie P
Old 03-25-2016, 06:03 AM
  #12872
Hydro Junkie
I've got a quick one then. Pilot this time:
1) This pilot's skill was legendary in his country's military
Old 03-25-2016, 07:02 AM
  #12873
Ernie P.
How about the best of them all; Hans Marseilles? Thanks; Ernie P.
Old 03-25-2016, 07:08 AM
  #12874
Hydro Junkie
Not Hans but I will send you another clue:
2) The plane he flew was considered obsolete when he flew it
Old 03-25-2016, 07:46 AM
  #12875
HoundDog
My Feedback: (49)
HoundDog's Avatar
[QUOTE=uncljoe;12193839]If anyone has a question fire away, Sorry about that the B 26 was built by DOUGLAS brain cramp
Joe[
/QUOTE] https://en.wikipedia.org/wiki/Douglas_A-26_Invader
Unc-Joe an interesting facts about the B-26 and A-26
Douglas A-26 Invader
From Wikipedia, the free encyclopedia
Not to be confused with Martin B-26 Marauder.
[TABLE="class: infobox, width: 315"]
[TR]
[TH="colspan: 2, align: center"]A-26 (B-26) Invader[/TH]
[/TR]
[TR]
[TD="colspan: 2, align: center"][/TD]
[/TR]
[TR]
[TH]Role[/TH]
[TD]ground attack; light bomber[/TD]
[/TR]
[TR]
[TH]Manufacturer[/TH]
[TD]Douglas Aircraft Company[/TD]
[/TR]
[TR]
[TH]First flight[/TH]
[TD]10 July 1942[/TD]
[/TR]
[TR]
[TH]Retired[/TH]
[TD]1980 Colombian Air Force [SUP][1][/SUP][/TD]
[/TR]
[TR]
[TH]Primary users[/TH]
[TD]United States Army Air Forces
United States Air Force
United States Navy
French Air Force[/TD]
[/TR]
[TR]
[TH]Number built[/TH]
[TD]2,452[SUP][2][/SUP][/TD]
[/TR]
[TR]
[TH]Unit cost[/TH]
[TD]US$242,595[SUP][3][/SUP][/TD]
[/TR]
[TR]
[TH]Variants[/TH]
[TD]On Mark Executive, Marketeer, and Marksman[/TD]
[/TR]
[/TABLE]
TheDouglas A-26 Invader(designatedB-26between 1948 and 1965) is a twin-enginedlight bomberand ground attackaircraft that was built byDouglas Aircraft Companyduring World War II which also saw service during several major Cold War conflicts. A limited number of highly modified United States Air Force aircraft served in Southeast Asia until 1969.[SUP][clarification needed][/SUP] It was a fast aircraft capable of carrying twice its specified bomb load. A range of guns could be fitted to produce a formidable ground-attack aircraft.[SUP][4][/SUP]
A re-designation of the type from A-26 to B-26 led to confusion with the Martin B-26 Marauder, which first flew in November 1940, about 16 months before the Douglas design's maiden flight. Although both types were powered by the widely used Pratt & Whitney R-2800 Double Wasp eighteen-cylinder, double-row radial engine, they were completely different and separate designs — the Martin bomber originated in 1939, with roughly twice as many Marauders (nearly 5,300) produced in comparison to the Douglas design.
[TR]
[TH="colspan: 2, align: center"]B-26 Marauder[/TH]
[/TR]
[TR]
[/TR]
[TR]
[TD="colspan: 2, align: center"]A US Army Air Forces Martin B-26B Marauder "Dee-Feater" (X2-A) of the 596th BS 397th BG 9th AF with D-Day invasion stripes[/TD]
[/TR]
[TR]
[TH]Role[/TH]
[TD]Medium bomber[/TD]
[/TR]
[TR]
[TH]National origin[/TH]
[TD]United States[/TD]
[/TR]
[TR]
[TD]Glenn L. Martin Company[/TD]
[/TR]
[TR]
[TD]25 November 1940[/TD]
[/TR]
[TR]
[TH]Introduction[/TH]
[TD]1941[/TD]
[/TR]
[TR]
[TH]Status[/TH]
[TD]Retired[/TD]
[/TR]
[TR]
Free French Air Force
Royal Air Force
South African Air Force[/TD]
[/TR]
[TR]
[TH]Produced[/TH]
[TD]1941–1945[/TD]
[/TR]
[TR]
[TD]5,288[SUP][1][/SUP] [SUP][Note 1][/SUP][/TD]
[/TR]
[TR]
[TH]Unit cost[/TH]
[TD]$102,659.33/B-26A[SUP][2][/SUP][/TD]
[/TR]
[TR]
[TH]Developed into[/TH]
[TD]XB-33 Super Marauder(Unbuilt)[/TD]
[/TR]
[/TABLE]
