NEW Top Flight P-40??? 1/5 scale
#1126
My Feedback: (8)
RE: NEW Top Flight P-40??? 1/5 scale
I cut my tubes so they are just inside the lip of the hole. The force of the exhaust expels the oil past the fuse. There is hardly anything on the fuse bottom after several flights. Cooling has not been an issue with that big opening on the back of the cowl. DA 50
#1128
My Feedback: (10)
ORIGINAL: lomcevac540T
Mine has a DA 60 in it, this is how I ended up making mine work. I ducted the air back to the cylinder while closing in the intake, and cut some vents in the bottom. I was able to lean the engine down and it stays cool.
Thanks.
#1130
ORIGINAL: dasintex
Nice set up, others have posted and have not opened their cowls up other than for the Exhaust Tubes, I think I will try it as I had planned and if over heating becomes an issue I can always open the cowl up later like you have done; I appreciate you going to the trouble of posting your photos, it has given me some ideas for any future project or alteration to my P-40; I bet that DA60 makes your bird smoke!
Thanks.
Thanks.
#1132
My Feedback: (81)
Dle 55 and a 22x10, running rich and mine hauls nicely!!!!! Cowl is open on bottom like most of my gasses. My da85 didnt like confinement....
And screaming down the deck in front of the crowd, I have had no one notice the hole.....everyone is looking at a set of teeth coming down the pipe!!!!!
#1133
I am ready for my first flights. They will be without the cowl on my DA-60. I plan and putting a flat plate through the cowl with everything below the bottom of the cly on one side and the cly and muffler on the (hot side) other. From what I have read on this thread it sounds like the carb is getting fooled by the high pressure inside the cowl so it will be seperate from the Hot side of the engine by a baffle . I have the exhaust tubes just about 1/8" proud of the cowl.
I have the CG set per the instructions (5.5" back from the LE at the fuse) were are you guys flying your CG at ?
I have a Menz "S" 22x10 woody
Any other ideas or suggestions?
Sparky
Sparky
#1134
My Feedback: (17)
MS
I was installing my retracts today (Robart #150 as recommended) and found that I had to add a 1/8" shim to the bottom of the landing gear blocks to allow the retracts to fold flat. Has anyone else had to do this?
#1139
My Feedback: (12)
IL
Have been getting some stick time on my P 40.
I am now getting comfortable on flying and landing.
This past weekend I changed out props from a XOAR 23/8 to a 20/8*14 TopFlight
This was from a fellow club member who has been flying a TF P 51 that has had a radar gun on it at 105mph.
I NEVER thought I would say I fly with Zinger Props, however we flew in formation and he had to back off his throttle three clicks so I could keep up with.
As of now I am sold on this combo.
Take off and landings are a little different, SLOWER on take off, but faster on LANDINGS.
At least that is how it felt and looked.
I now look forward to flying this plane.
Also have TF 22/6*10 I might try as the P 51 owner has had good results on that prop too.
This is with a G62 with Bennent muffler - 32:1 oil mix.
#1144
Just an Update...
I am still waiting for my first flight . The weather here in the Midwest has been so hot I just don't feel like going out in 100 degree weather to have fun. I will update you when I do and maybe some pictures. I don't anticipate any issues with the plane but you never know.
Sparky
Sparky
#1147
My Feedback: (8)
Hate to say I dinged mine two weeks ago flying in 20mph winds....Id call that pilot error in itself, but shes all patched up and ready to go good as new I love this plane so much I bought a second one during the gold member discounts and plan on stripping glassing and painting it.
Jimmy
Jimmy
