caldera reverse problem
i have a problem, i have progtam the esc for voltage setting. After this program, reverse dont work. I have check on the esc the running mode and is ok. Do you have an idea?
RE: caldera reverse problem
ORIGINAL: mart271
ORIGINAL: mart271
direct on the esc
direct on the esc
Not sure what you mean. But it sounds like you changed the driving mode when you tried to change the voltage setting.
Programing the ESC with a ezrun program card makes life 100 times easier.
1st, try recalibrating the ESC to the radio.
ORIGINAL: mart271
i have try, and they change anything.
It is pretty tricky to count all the "beeps" when setting the ESC with just the radio and button on the ESC. The Program card makes the chore a breeze.
If you have the program sheet for the ESC (can also be found online) follow the steps for changing the driving profile
