Redcat Racing Tsunami Thread
#302
RE: Redcat Racing Tsunami Thread
just gave a quick once over, its a 5x8 bearing here's a couple of links:
http://www.clermontmotorsports.com/s...5x8x2.5/Detail
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXM766
you will need 3 bearings if you dont use the second link or 2 bearings and the needle bearing in the second link. i would suggest getting 3 bearings,
you will need a 3/16 tension pin cut down to extend the shaft and a larger washer to keep the bell on, neither is a big deal.
#304
do you mean set them up to toe in or have it happen out of no where? your supposed to have a little toe out in the front and a little toe in on the rear.
#305
really ok i just noticed thar mine were toed in a bit and couldnt figure our how that happened because there is no adjustment for that in the back. did you read my post about my engine and tranny problems?
#306
no bro, just looked over stuff fast, long weekend, going to bed in a few. email me or pm me with the question or a link to the thread.
#307
hey ehroof do you think these tires would work on my tsunami?
http://www.amainhobbies.com/product_...oducts_id/5259
#310
ORIGINAL: eminentguitar
not on the rims, you will need 2.2 rims. and btw, the rims with the gladiator tires are a little over 4in.
#312
nah, just take your time and use a medium ca glue. mount the tire to the rim then pull the tire away and put a dab of glue. Keep doing it a little at a time, you'll be ok.
#313
ok. I just bought a failsafe today. I ordered some parts from red cat and they sent me all of the same part now I have 4 sets of the 2015 lol oh well im sure they will get used up some day. Those tires I showed you do you think they would be a good loose dirt tire?
#317
Yokohama geolanders. Thats all the tire you will ever need. Great all around tire, sticks like glue and wears like steel. I have thes on my Jato and have tried a dozen other tires and none have come close. The Geolanders are awsome. But they are only for 2.2 wheels.
#320
TX
ORIGINAL: twomanytoys
LOL, on a side note, Yokohama Geolanders are good truck tires on a real truck too, lol
#324
CA
Only in you sit in the snow with no pants on
If it cold like that you do need to wrap the engine with foil to keep it warm or it will die easly[:-]
