Finally got my tower order today
Ok guys, i got my order today, put the 13/18 clutch bell in and the bearings that greg gave me and what a difference, i will post some video of it tomorrow, the lightning too.
OH
RE: Finally got my tower order today
Glad to hear you like the 13 and 18 clutch bell. I told you it had sick low end. You have it on the tsunami right? Just imagine it on the buggy. FONG[8D]
OH
Actually I did have it happen on the road. My dad said I hit a rock LOL but then it did it on the way back. It only happened 3 times. In the grass and in the dirt this thing is awesome also. I do need to get some good tires on it , now with all the low end power. It spins real easy.
Later FONG[8D]
Later FONG[8D]
BC, CANADA
eroof, could you please post the order you have the bearing / bushing / washers in. I pick my bushings up Monday.Can't wait, I already have the bell/ bearing and lots of the washers hopfully I don't break anything this weekend . Thanks
i used 3- 5x8x2.5 bearings instead of the needle bearing. It goes in this order, washer, bushing, needle bearing, bushing, washer lock washer screw. You will need to pick up a 3/16 tension pin and cut it down to size (like 1/4 inch) to extend the where the screw goes in past the clutch bell. Home depot or any hardware will have the tension pin, you may need a longer screw too.
OH
I did the same thing as Ehroof. I used 3 bearings instead of the needle bearing. I also used the tension pin. I used in order washer 3 bearings, big washer that came with the needle bearing, small washer that came with the stock bell, tension pin, then Allen screw. I didn't use the small lock washer that came with the stock clutch bell. Just because the Allen screw was not long enough to use the lock washer. I also put blue locktite on the Allen screw. Hope this helps.
I used the 3 bearings because the bushings seem to be a little too tight inside the clutch bell and I could not get it to spin freely. But you might be able to get them to work for yourself. I picked up 12 of those washers at my lhs for 14 bucks.
The damn hobbytown USA people tried to sell me 2 bearings for 6.99 I said no way. I told them that , I knew they had a lot cheaper ones, and then they said, you mean these. Again I hate Hobby Town USA[:@] Anyway get this 13 and 18 to work and you will love it.
This is the bearing I bought. Duratrax
[link]http://][link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD109&P=ML[/link][/link]
Peace Out FONG[8D]
Peace Out FONG[8D]
hey glk get a set of 2.2 rims with a set of proline 87's they are a great tire and you cant beat the wide foot pathbetter grip.....
here are the tires http://www2.towerhobbies.com/cgi-bin...?&I=LXDX23&P=7
if you run on the street more you may wanna tro one of these
http://www2.towerhobbies.com/cgi-bin...?&I=LXDU13&P=V
good all arond offroad on road tire
