Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Aftershock 8E tire issues
Reply
Old 08-03-2010, 09:14 PM
basketballfan60123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Aftershock 8E tire issues
To owners of the Aftershock 8E;
Is anyone else having issues with the sidewalls of the their tires tearing ?
I think it is probably from running the car WOT and the tires ballooning up; any ideas why this is happening and what I can do to prevent this?
Maybe taping the inside of the tire; how's this done?
basketballfan60123 is offline
Old 08-03-2010, 11:04 PM
Mickstix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Aftershock 8E tire issues
"Strapping"tape is the best, imo.. You put it on the inside of the tire, in the middle, and it acts similar to the belts ofa "belted radial" tire.. Before putting the tape on, use some alcohol on a rag, and wipe the inside of the tire, so it'll be good and clean, and the tape will adhere better.. You can find "strapping"tape at most any hardware type store.. It's very similar to regular packing tape, but it's got filament/fiber lines that run length wise, along the spool of tape.. Good luck!
Mickstix is offline
Old 08-04-2010, 11:49 AM
hhvg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You could convert it to 17mm with backdraft parts and run buggy badlands. Mine work great. They hold up to abuse so much better. They also make it handle, steer, and get traction way better. Myin air jumping response also improved. Ebay is a good place to get used 17mm buggy tires. Look closely at the buggy diagram on redcatracing.com to find out what parts you need.
hhvg is offline
Old 08-04-2010, 09:32 PM
foxys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Or just get an MPO-01 Wheel Hex set and mount those buggy tires...
foxys is offline
Old 08-04-2010, 10:42 PM
basketballfan60123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got that already; I am just trying to beat on the tires a little longer
Might try the Proline Knuckles 1:8 Buggy Tires
Old 08-04-2010, 10:56 PM
hhvg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: foxys
MPO-01 is a 12mm aluminum upgrade from 12mm plastic. I have it as well.If you want to run 17mm wheels you need to change the hex to 17mm. You would need the 17mm hub AND the backdraft end of the backdraft cvd.The 17mm hub attaches to a different cvd end than the 12mm aftershock hub.
hhvg is offline
Old 08-04-2010, 11:01 PM
basketballfan60123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: hhvg
Quote:
ORIGINAL: foxys
MPO-01 is a 12mm aluminum upgrade from 12mm plastic. I have it as well. If you want to run 17mm wheels you need to change the hex to 17mm. You would need the 17mm hub AND the backdraft end of the backdraft cvd. The 17mm hub attaches to a different cvd end than the 12mm aftershock hub.
I picked this up from urchobby
http://www.urchobby.com/proddetail.php?prod=BS17MM-Kit
Old 08-04-2010, 11:12 PM
hhvg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awesome! There you go. Thats exactly what I wastalking about.All the backdraft parts:17mm hex, wheel nuts, and the cvd ends for a great price! And I thought they were only available seperatly!
hhvg is offline
Old 08-05-2010, 08:09 AM
billymare
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got the same kit from Kurt.. It gives you so many more wheel options.
billymare is offline
Old 08-06-2010, 12:07 AM
Mickstix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
URCHobby still the place to get your Redcat parts and upgrades I see!!   Nice looking wheel upgrade kit, and the price is right too!!!
Mickstix is offline
Old 08-14-2010, 11:05 PM
pineiroadrian
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im having the exact same problem, im trying sc8 tires next.
pineiroadrian is offline
Old 08-14-2010, 11:20 PM
basketballfan60123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: pineiroadrian
Same here.
Old 08-15-2010, 12:14 PM
hhvg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had the sc8 and the sidewalls tore on all for of mine. It was because the rims have hard ribbed plastic behind the sidewall of the outside part of the rim. When cornering the hard plastic rubs the side walls until it wears through. You can even feel the hard plastic inside if you squeeze the sidewall.
Some of the sc tires that have a different innner and out diameter are prone to this. I went to buggy badlands 17mm because the inner/out is the same and they have the most traction out of all the tires if tried (trencher, aftershock, sc8, bow tie, gadiator, slash plat 4x4, slash rtr 4x4, etc.)
hhvg is offline
Reply
Display Modes
