ORIGINAL: hhvg
ORIGINAL: foxys
Or just get an MPO-01 Wheel Hex set and mount those buggy tires...
MPO-01 is a 12mm aluminum upgrade from 12mm plastic. I have it as well. If you want to run 17mm wheels you need to change the hex to 17mm. You would need the 17mm hub AND the backdraft end of the backdraft cvd. The 17mm hub attaches to a different cvd end than the 12mm aftershock hub.
I picked this up from urchobby
http://www.urchobby.com/proddetail.php?prod=BS17MM-Kit
