A Beginners Quest
IL
RE: A Beginners Quest
FFox,
I will probably add rudder to mine or build another one so I can do knife edge and some other stuff requiring rudder imput.
As for your wheel question, try www.towerhobbies.com - they have everything you would ever need for R/C.
11x6 prop is 11 inch diameter with the pitch being 6.
If you use a 40LA, you should use either a 10x6 or an 11x4. You'll get more thrust out of the 11x4, and the 40LA is more of a torquing engine than a rev engine so it should like it better. 10x6s are the standard do it all props for anything in the .40 cu in range.
As SM pointed out, the 11 is the diameter and the 6 is the (theoritical) pitch.
Although, I still have reservations about you wanting to fly a Dogfighter as a first plane. And the radio, well you can get the hitec Laser 6 channel with 4 standard servos for 140$ on Tower, plus 3 micro servos if you want them at 16.50 each will get you a fine setup for 205$
If you still plan on getting a 40LA, its all good because you can build a BUHOR 25 for it.
good luck with the crashing...I mean...flying.
But good luck trying!
Brad
MT
The hitec radio, it comes with 4 standard. and i can ADD 3 micro? that would be 7 servos? Or did i misunderstand that?
Search: How did you score your wing? i just cut mine infront of the dowel and above it, it seems a little weak i think, i put tape around mine. Also, did you have a problem with the 2mil lining up? or was taking the dowel out enough to remedy that?
My airplanes body is nearly compleate. tonight or sometime soon im going to order the engine. After i get paid (the picture is where i work) ill buy the radio and equipment. I hope to finish this soon. And i hope my electric comes back soon - im wanting to fly
-Fox
-Fox
AL
ORIGINAL: RC-FIEND
What CHRIS said is all HOG WASH , he just needs someone to disagree with because he's afraid to disagree with his boss.
#31
NJ
You ever get your SimplePAD to fly RC?
#32
Well you want 3 micros for your Dogfighter, ideally. You can keep the standards for other projects. I did that when I bought my first radio. It came with 4 standards and got 3 micros for the plane I was going to fly. When I got tired of my little airplane and wanted to move to the bigger .40 size stuff, I already had the servos waiting. No need to order another set of servos.
#33
IL
FFox-
I scored the leading edge as per plans, I used a small Phillips screw driver. I've been told the leading edge dowel is only necessary for combat (I'm not sure it's even needed for combat - I've seen a number of Dogfighters used in combat that don't use the dowel).
#34
the only thing the dowel in the leading edge does is to help stop someone else's prop from slicing through your wing during a midair. If your not flying combat, its really not necessary at all.
#35
NJ
This has to be one of the cleanest SPAD planes I have ever seen . I assume you flew it already ? And how did you do the graphics on the wing ? paint ? . GJ
RCF esq.
RCF esq.
#36
IL
Thanks Fiend!
I've flown it a bunch! It still looks almost as good as the photo (bottom of fuse is scuffed up and stained a little). I probably took that photo after a couple of flights. I mixed 50% windshield washer fluid with 50% rubbing alcohol (91%) to clean it with - works great with no residue.
The graphics are all hand cut out of sign graphic stick on plastic. I printed the Iron Cross from my PC and made a template - very easy. Sprayed wing with windex, placed Iron Cross where I wanted it and then squeeged bubbles and windex out from under the graphics.
#37
MT
Search:
What do you mean you scored per plans? They dont day how to score or anything they jsut say "score as needed" shich i thought that ment to cut part of the corpplast so that its bend. This isat right obviosuly, Howd you use a screwdriver?
-Fox
-Fox
#38
some plans are much more detailed than others. This is one of the main reasons that its suggested so often to build one of the trainers - specifically the debonaire or spadet to start with. The plans are very detailed, and will help you learn how to work with coro and gutterpipe - something the combat plans simply don't do. I highly suggest that you read through the debonaire plans thoroughly - most if not all of the problems your having would be explained by examining these plans.
Here's a picture of Tattoo scoring a wing:
http://www.spadtothebone.com/SPAD/De...page_2021a.JPG
#39
TX
Fox,
Looking better all the time! I like your full scale job in the background, too!
Searchman,
Beautiful Dogfighter! Very slick! Mine is on channel 36 too, guess you're safe for now, we can't fly in the same heat![X(]
Blue skies,
DL
Searchman,
Blue skies,
DL
#41
MT
Lol thanks DL
I ran into one of the people from here today at work actually. It turns out one of the people i met on here knew my mom, and worked across teh street from me. And i didnt know till today, lol! So i think i might have got set up with a older engine and radio atlest untill i get my own. So i might have my plane up and flying before too much longer. I have an idea for adding tail dragger to my plane, but i cant upload a bmp on here. If you would like to view these Pm me.
-Fox
-Fox
#42
TX
RC-FIEND,
I went to a local sign shop and showed him what I wanted coro and sign vinyl for; an airplane not a sign. When he saw that I wasn't going to make a sign and take away from his business, he warmed up to the idea and showed me his scrap bin. When they make signs they have scrap that they don't use, and save it for teachers with projects for their kids, etc. I got a bunch of all different colors, holographic stuff, reflective stuff and all for free. I even offered to put him on a buddy box and let him fly the final project, but he hasn't taken me up on it.
I've had the same vinyl on two planes for over two years and it's just now starting to come up at the edges.
Take a wing into a sign shop and show 'em what you need the vinyl for, and I bet you might have a new SPAD RC student to boot!
Blue skies,
DL
Blue skies,
DL
#44
NJ
Thanks DL I visited the sign shop where I bought 4mm coro, but they were closed and only take appointments for weekend hours. Next time I go, I will show the lady the DDust I made and maybe she will warm up to me [:-]
RCF esq.
RCF esq.
#45
MT
I checked out my signshop - they were jsut closing so they were rushin out. But they tol dme they cold sell me a 4x8 4 mil for 25$!! i think that buying for harbor - where i can get 2 2mils and a 4 mil for 21$ and paying for shippings is MUCH better. I have a nwe work space set up downstairs...really nice desktop - like 5x5'. or something simular. And if im waiting for my glue to dry, i can just turn around and play drums or something . I finally got my plans converted to JPG, so i can post them here now i believe. I made this up a couple days ago while i was working on our RV-10. i think it a good idea - im sure someones made it up before me.
-Fox
-Fox
#46
CO
Nice work space, enjoy it[8D]
rrh
#47
Make your tail wheel bracket into an 'L' and poke it in through the flutes of the rudder. Bring it down through the hinge on the elevator and just bend it to recieve the wheel... I'll try to find a pic.
Oh, and love the poster of the babe. I need one over my work area.
#49
MT
Haha! I thought youd all enjoy the randomness of my area. Too bad tou cant see the other side, my mom has elk skins and tanning supplies everywhere, and i have a tone more stuffed animals. Muldoer, i think i understand your directions, not quite though, a picture would be great!
-Fox
-Fox
#50
TX
Fox,
Here's a pic that ChrisSpad showed me a while ago. You just run a piece of music wire up through the elevator hinge, and rudder hinge, bend it 90* and stick the bent end through the flutes in the rudder. It may work better if it goes through the rudder between the control horn base and the control horn. The bottom is just a tail skid, but you can put a 90* bend in the bottom and put a wheel on, then a wheel collar and a piece of fuel tubing CA'd to the wire to lock everything on. This works like a charm and has survived literally hundreds of take offs and landings in a grass cow pasture (beware of the moo-moo poo-poo![X(][:'(]).
Blue skies,
DL
Blue skies,
DL
