RE: A Beginners Quest
Thanks Fiend!
I've flown it a bunch! It still looks almost as good as the photo (bottom of fuse is scuffed up and stained a little). I probably took that photo after a couple of flights. I mixed 50% windshield washer fluid with 50% rubbing alcohol (91%) to clean it with - works great with no residue.
The graphics are all hand cut out of sign graphic stick on plastic. I printed the Iron Cross from my PC and made a template - very easy. Sprayed wing with windex, placed Iron Cross where I wanted it and then squeeged bubbles and windex out from under the graphics.
