Go Back  RCU Forums > RC Airplanes > Pylon Universe - RC Pylon Racing > Scale Racing
Reload this Page >
Eighth Scale Aviation Tsunami 517" build
Scale Racing Discuss all aspects of semi-scale pylon racing.
Old 03-14-2016, 05:15 PM
  #76
Iron Dog
Iron Dog's Avatar
Originally Posted by MFLOOD3800
Would it be an issue if I glass the rest of the wing after already glassing the center?
I would like to have a fully glassed wing at this point and it appeared very easy. I will still cover my fuse, but would like the added strength to the wing and the hassle free cover of wrinkles and such too. My fuses stay pretty tight, its usually the wing that plays hide n seek.
Marty,
Beings the center section has already cured, technically, you are looking at a mechanical bond, rather than a chemical bond. But, beings glassing the remainder is primarily a finishing method, rather than any kind of true structural reinforcement or structural part fabrication, that really is not an issue, at all.
So, I say . . . GO FOR IT!
Another recommendation I offer is using Pacer's Z-Poxy Finishing Resin for fiberglassing with lightweight cloth as an alternative to iron-on covering material, utilizing this method. This resin's viscosity makes it easier to work with in this application. It wets-out the cloth REALLY well and sands easier than any other epoxy I have yet used. I also prefer to apply to larger surfaces (such as an entire wing) with a mini 1 1/2 - 2" paint roller. This won't snag the fragile light cloth the way that some disposable brushes do.
(Please make sure it is their "Finishing Resin", not their 30-minute or similar bonding epoxies. Please also note that Finishing Resin is specially formulated for finish-work purposes, but would therefore NOT be appropriate to use in fabrication.)
Old 03-15-2016, 04:36 PM
  #77
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
I too used a roller to apply the epoxy on wing center section, versus a brush, then once evenly applied, I squeggied out excess.
I will be using the TP method from now on, less messy, wont pull the strands loose on the edges, and just appears to be a lighter - cleaner over all application.
Thanks guys
Old 03-16-2016, 06:41 PM
  #78
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
Why wouldnt someone be able to simply use a roller and epoxy only , no cloth, on the wing now that the strength part is accomplished?
Why would it require light cloth if all I was after was a base for paint?
I would consider rolling epoxy on the rest of the wing and the fuse but adding the cloth is a step I am wondering if its needed for cosmetic purposes rather than structural ones?
Old 03-16-2016, 07:02 PM
  #79
tdstaf
tdstaf's Avatar
The cloth fills in the wood grain and keeps it from cracking later.
Old 03-16-2016, 08:21 PM
  #80
Tommy_Gun
Tommy_Gun's Avatar
No one says you have to do anything.
Keep in mind, when applying the cloth, you only want to leave just the amount of epoxy needed to bond the fabric to the surface. Any more epoxy than that is excess weight.
Once the initial application is cured, the surface is sealed and the second application just fills the weave a bit.
A wet roller will not remove the desired amount of excess epoxy.
Do as you like.
Old 03-16-2016, 10:01 PM
  #81
Tommy_Gun
Tommy_Gun's Avatar
Forgot to mention,
I prefer to use a disposable acid brush as I waste less epoxy in the application process.
A larger brush or a roller has to be itself saturated to a point with the epoxy before it actually works to apply the epoxy to your project.
Helps make the material go a bit further.
Old 03-17-2016, 04:49 AM
  #82
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
Thx guys
Yea I wasnt going to use the roller to remove excess
I was just wondering why the cloth was needed if it wasnt for structural integrity
I am a fan of the TP method.
I am going to use it somewhere on this Tsunami, probably the wing.
Im looking at doing the fuse as well before I go too much further as it is a great shape for this, not many curves or angles for a rookie to try it on.
You guys are a great help = thx again
Old 03-17-2016, 05:21 AM
  #83
kane
Marty,
Just saturating the wood will also give undesirable results due to sanding through in some spots while sanding the epoxy. The same thing can happen with cloth it is just easier to spot. The lightweight cloth provides a smoother base for the finishing steps.
Once the cloth is attached, the next steps will determine what your finish looks like. Filling the weave with resin is much better than filling it with paint. A nice smooth base will provide the best results when painting or even covering.
DK
Old 03-17-2016, 10:57 AM
  #84
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
Thx Dan
It makes sense.
I was just needing to know the "whys"
Old 03-27-2016, 07:47 PM
  #85
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
I made a decision and ordered the finishing resin instead of monokoting. I will lay 3/4 oz and resin mixed with equal amounts of alcohol to thin it out so it stays as light as possible. After the wing is done, I will determine what I want to do with the fuse.
I saw a video that virtually eliminates the fraying of the cloth. By laying the cloth well over the edges and glassing the cloth a bit beyond where you need it, it will cut off to a clean edge. I made the mistake of pre cutting the cloth to come up just shy of the outer edges.
Im wanting this to be under 8.75 lbs when done. A weight of 8.25 would be fantastic.
Im excited to return home and get going on this as it is on the downhill side of things now.
Servos have been ordered and all components are either there waiting or on there way.
I am already throwing around the idea of getting the smaller Tsunami for the new YS80. I believe that would be a great Gold plane, and I already have almost everything needed to build it. Just a few pieces of sheeting needed and more time. Wish I could buy some time.
Old 03-28-2016, 09:57 AM
  #86
airraptor
My Feedback: (66)
I have 4 of the little Tsunami kits waiting to be built. i plan to have one of each for the NATS. My Tsunami came out at 7.25 pounds and I over built a it in a lot of places. I think if i built it the way Tim designed it it would be around 6 to 6.5 pounds.
Old 03-28-2016, 04:25 PM
  #87
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
7 1/4 is great. That makes me think mine will be closer to the 8 - 8 1/2 range with glassing. I too over built my wing, and bottom fuse cowl areas.
Old 04-05-2016, 01:49 PM
  #88
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
Hoping to get back on this now that I got back to Utah. First I had to build a new Q40 racer, and it is ready to maiden so next is the Tsunami
ID:	2156103   Click image for larger version
Old 04-05-2016, 03:36 PM
  #89
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
Since I decided to try glassing, (I didnt think I would on this particular plane). I opted for the Z poxy finishing resin, 3/4 oz cloth, and the toilet paper method. I used a hobby brush to brush it all on, then laid out charmin 2 ply quilted unscented not on sale high dollar toilet paper, then I dabbed it lightly with hand let it sit for a bit then used a roller to roll it out with TP still on there. I started in middle for everything I did, and just kept rolling to the outside. It turned out amazing.
Glad the wife isnt here this trip, as I used her high end TP, her paper bowls for this part. I have access to all the household items of my choosing.
Glad she's not an RCU member.
ID:	2156114   Click image for larger version
ID:	2156115   Click image for larger version
ID:	2156116   Click image for larger version
Old 04-05-2016, 06:47 PM
  #90
Iron Dog
Iron Dog's Avatar
So glad to hear it went well and was a very positive experience for you, Marty. Well done!
Old 04-05-2016, 07:58 PM
  #91
Tommy_Gun
Tommy_Gun's Avatar
That's why I like this method.
If I can make it work, anyone can do it.
And, it's open to tweaking for what the individual prefers to do.
As long as it looked almost dry after the first application. That's how you prevent excess weight buildup.
Old 04-06-2016, 10:40 AM
  #92
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
Got busy before work today:
Put second filler coat over the bottom side of the wing and squeegied out.
Im waiting for my 3/4 oz cloth to arrive, so I did what other parts I could
ID:	2156178   Click image for larger version
ID:	2156179   Click image for larger version
Old 04-06-2016, 07:34 PM
  #93
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
I have all the misc parts done now front and back.
I discovered if you take the resin and go beyond the surface you are trying to adhere into the cloth more, it cuts better w/o fraying.
I will scrape with a razor blade tomorrow and sand if needed and it will be ready for primer/paint.
Still waiting for cloth to do top of wing and fuse.
Once the glassing is done, primed and painted- Ill finish the assembly of tank install, aileron servos and linkage and then figure out the front cowl/engine install.
Old 04-06-2016, 07:43 PM
  #94
Tommy_Gun
Tommy_Gun's Avatar
Learn as you go.
Old 04-10-2016, 06:16 AM
  #95
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
Finally got the fuse glassed as well as the top of the wing. I did the fuse in one piece and it was pretty simple as there werent any turtle decks to deal with.......
I could see in that scenario, one would want to do the turtle deck first in its own piece of cloth (that is if you use the cloth I did) but perhaps there is cloth that does corners and contours better than what I used?
Thx for the putting the seed of suggestion in me to go this route, I feel much more confident in the longevity of this plane in a racing environment on high nitro now.
ID:	2156593   Click image for larger version
ID:	2156594   Click image for larger version
ID:	2156595   Click image for larger version
ID:	2156596   Click image for larger version
Old 05-04-2016, 08:26 PM
  #96
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
Spent the afternoon out working on the Tsunami. Got the fule system 100% finished incl the fuel dots. I also got the RX mounted, JR HD on/off switch installed, throttle servo in and plumbed and programmed, all hatches in place, cowl mounted, needle hole cut out, Horz stab epoxied in.
It is more like an ARF now which is fine by me. It has been a long busy winter, I'm glad I decided to build this.
ID:	2161004   Click image for larger version
ID:	2161005   Click image for larger version
ID:	2161006   Click image for larger version
ID:	2161007   Click image for larger version
Old 05-05-2016, 05:54 AM
  #97
FlyerInOKC
FlyerInOKC's Avatar
Looks almost ready to tear a hole in the sky!
Old 05-05-2016, 11:21 AM
  #98
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
Had a brief amount of time this afternoon at lunch so I got the vert stab on: I am hoping it tears a fast hole in that sky
Name:	tsunami hz stab.jpg
Old 05-05-2016, 08:01 PM
  #99
airraptor
My Feedback: (66)
marty all we now is one of these in 100" wing.......... I really want to race USRA.
Old 05-06-2016, 03:59 AM
  #100
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
The Tsunami in the Unlimited class was plane to have in the 90's. Today it is either the Stiletto, Ashley or the Yak.
All 3 are great planes. I may jump back into it next year if things slow down enough to fit it in. The group of racers is currently smaller than in years past, but the competition is highest its been. No easy heats, all planes very equal. Let's do it !!
