Giles Built up wing help
Hello
I am designing a wing for a giles 202 but i want the both spars to come in parallel and not in the tapered line so when i join the wing i get parllel spars for the joining the ply doubllers, any suggestions or pics, i am using a free ware software to design the wing.
Highfly3D.
Highfly3D.
ON, CANADA
RE: Giles Built up wing help
Not sure if I understand your question correctly but I assume this wing is symmetrical? If so, place the top and bottom spars at the widest point of the wing ribs.
Cheers,
John
Cheers,
John
ON, CANADA
I took a good look around myself for one and ended up concluding that buying compufoil3d was the best route to go. However, there are a few websites out there that will calculate the coordinates for airfoils. You can then input them into your cad program and draw in your own spars etc...
Cheers,
John
Cheers,
John
I would cut foam wings, the taper leading edge and straight trailng make for difficult build solution. Here is a photo of 87" Giles wing platform in foam.
Tony Hallo
Tony Hallo
