Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
Who makes scale Edo floats?
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 02-08-2012, 09:10 PM
H5487
H5487's Avatar
Default Who makes scale Edo floats?
Hi Guys,
I'm building a 1/5th scale (77") Ziroli Stearman and I'd like to put it on a nice set of scale Edo floats. (See the attached pic.) Who makes quality scale Edo floats? I'm assuming that 44 to 45 inchers would be appropriate for my 59 inch fuselage. (The 75% of the fuselage length rule applies to biplanes too doesn't it?)
Harvey
Old 02-09-2012, 03:17 AM
JimCasey
JimCasey's Avatar
Default RE: Who makes scale Edo floats?
Try here: http://www.seacommander.com/
beautiful epoxyglass floats.  You pay for the quality tho' .
Old 02-09-2012, 04:58 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Unfortunately, I think they have been on hiatus since last winter, He had a post up about loosing his shop lease, now I see the company is for sale,,
Balsa USA has a couple float kits too (built up)
Old 02-09-2012, 05:38 AM
ByLoudDesign
ByLoudDesign's Avatar
I email Sea Commander several time with no response. I wanted to include a float option on my 1:4 SR-9. They had some nice size strut fairings that would have worked well on my 1:8 scale Dornier Do-24T. But alas !!!!
Old 02-09-2012, 07:07 AM
H5487
H5487's Avatar
Thanks Guys! Maybe Sea Commander will resurface or someone will pick up their inventory and continue on. Unfortunately, Balsa USA only makes floats in 1/4 and 1/3 scale. I need 1/5.
Harvey
Old 02-09-2012, 07:20 AM
ByLoudDesign
I am still looking! AND hoping!! LOL,because I have found nothing!!! Looking for drawings for them are hard, and the proper size is so important to balance the A/C in the water as well as in flight!!!
Old 02-09-2012, 08:27 AM
bkind
This guy makes a kit
https://mraerodesign.securicom.ca/en...m?ProduitID=11
Brian
Old 02-09-2012, 09:43 AM
H5487
H5487's Avatar
ORIGINAL: bkind
Brian
Thanks but $270 is way beyond my budget.
Harvey
Old 02-09-2012, 09:50 AM
scale only 4 me
My Feedback: (158)
When you consider all that comes with that kit,, IMO that's not a bad price
Old 02-09-2012, 10:02 AM
H5487
H5487's Avatar
ORIGINAL: scale only 4 me
You might be right but it's still beyond my budget. I'd hate to think what the Sea Commander floats went for.
Harvey
Old 02-09-2012, 10:32 AM
scale only 4 me
My Feedback: (158)
Well 1/5 what? He calls those 18% Beaver that close to 5th scale for that plane. I bet they'd look fine on that size Stearman
Shoot the guy an email, since it's CAD and laser cut, maybe he can cut a set slightly smaller for you,, you'd have to tinker with the pre made fiberglass parts or use wood for that area, but that wouldn't be to hard to modify.
good luck,
p.s.
Sig has a 46" set, but their not a scale as those
Old 02-09-2012, 10:47 AM
Closterman
Did you know the exact length you need for your float ? MR Aerodesign can scale it at nearly any length you want.
Old 02-12-2012, 06:45 PM
SeaPlaneSupply
My Feedback: (7)
SeaPlaneSupply's Avatar
What type of scale EDO floats are you looking for? I can cut anything. The largest so far is 114".
Mark
seaplanesupply.com
Old 02-13-2012, 10:16 AM
H5487
H5487's Avatar
ORIGINAL: SeaPlaneSupply
What type of scale EDO floats are you looking for? I can cut anything. The largest so far is 114''.
Mark
seaplanesupply.com
Mark,
Thanks for chiming in. I've been looking at your website this morning . I THINK I need a set of 44-inchers but I need to measure the plans again before I'll know for sure.
Harvey
Old 02-13-2012, 06:54 PM
SIMCO
My Feedback: (33)
SIMCO's Avatar
Balsa usa sells a float kit
Old 02-13-2012, 06:59 PM
H5487
H5487's Avatar
ORIGINAL: SIMCO
Balsa USA only sells 1/3rd and 1/4th scale float kits. I need 1/5th scale.
Harvey
Old 02-13-2012, 08:24 PM
scale only 4 me
My Feedback: (158)
You keep saying that,, but a 1/5 scale Stearman Float isn't the same as a 1/5th scale Cub Float,, the Balsa USA size/scale (and many others) are based on their Cub kits.
Old 02-13-2012, 08:41 PM
H5487
H5487's Avatar
Yes, I get that. However, the Cub floats are light duty floats. While BUSA's quarter scale floats might be the right length for my fifth scale Stearman, I'm afraid that they would look like light duty floats with larger-than-scale features.
Harvey
Old 02-14-2012, 06:07 AM
scale only 4 me
My Feedback: (158)
OK, I see where you're going with this,,
Most available kits are just basic wood built up floats,, you can add as much scale detail as you want to make them look scale to your plane,, add more or fewer rivet line rows etc.
good luck
Old 02-20-2012, 08:16 AM
IIMAC
My Feedback: (7)
Check out seaplanesupply.com he is a great guy to deal with.
