new
IL
new
i am new to float flying. looking to get my first. thinking of getting the >Great Planes Seawind Seaplane EP ARF <[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSAG3&P=ML]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSAG3&P=ML[/link] is this a good starter seaplane?
GA
RE: new
There are good looking planes... but a challenge....
What I would suggest is for now (until you know you like it....) just convert one or your existing planes.....
RE: new
As long as you are an accomplished flyer, the EP version of the Seawind is a great way to get started.
I reviewed this plane for RCU Magazine last summer and it has become one of my favorite planes.
Unlike the big nitro powered Seawind, the EP version is very easy to get on and off the water with. And it flies GREAT!
The only thing to watch for is to make sure you waterproof the wing and cockpit area. You don't want to get that ESC wet!
One of the really nice things about it is that you can fly it off of grass until you get the feel for it and trim it out, then take it to the lake, pond, or whatever water you have.
Here's a link o my review. Be sure to check out the video
http://www.rcuniverse.com/magazine/a...article_id=917
RE: new
I have seen two of these fly so far. Both had in-flight failures causing ...well... unplanned meetings with earth/ocean.
The first one went in when the engine pod flexed forward on a throttle up after a low pass. Prop cut the fuse in two.
The second one snapped a wing in two pulling out of a dive. Could have been over stressed, but it didn't appear to be too abrupt a pull out.
RE: new
I've been pretty brutal with mine, and the only bad habit I have found is that if you are flying slowly, and then quickly advance the throttle to full, it will nose down due to the high, rear placement of the motor. This was only a problem once, when I was flying very low to the ground which resulted in a very short touch-and-go.
I have since learned that when flying slowly, you should advance the throttle gradually.
