RCU Forums - View Single Post - new
Thread: new
Old 12-03-2007 | 01:30 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: new
I've been pretty brutal with mine, and the only bad habit I have found is that if you are flying slowly, and then quickly advance the throttle to full, it will nose down due to the high, rear placement of the motor. This was only a problem once, when I was flying very low to the ground which resulted in a very short touch-and-go.
I have since learned that when flying slowly, you should advance the throttle gradually.
