Any body done an RC from a Static Model Conversion?
Old 11-25-2015, 10:27 AM
Jhdumas
Default Any body done an RC from a Static Model Conversion?
Hi all... I just purchased a couple of Juckenburg 1/16 static kits... The Hetzer and sdkfz 251 D... I would lik eto do an sdkfz 251 G Pak 40...
well my question is.. is it possible to make them functioning RC vehicales? Has any one done it? I have seen YouTube videos of running examples...
and Asiatam has a set of metal tracks for a nonexistant Hetzer....so apparently it can be done but, I have no idea how to do it?... does anyone know
of any fourm or online discussions?
any help in this regard would be helpful... Thanks in advance and I look forward to you're replies, Joe
ID:	2132455   Click image for larger version
ID:	2132456   Click image for larger version
Old 11-25-2015, 11:45 AM
manchu9inf
it can be done with a lot of work, making working suspensions, gun elevation, recoil, etc. It wouldn't be a battling tank, as many of the resin parts would not hold up to the stresses, but if you wanted something to move around on a nice flat surface, then more than likely doable. Again, only after a lot of work.
Old 11-25-2015, 11:53 AM
Jhdumas
I am certainly not afraid of the work... I was just hoping one of you guys had done it already and had some guidance to offer.. or maybe point me in the direction of a fourm string that I could follow...
Thank you all replies are welcome.. Joe
Old 11-25-2015, 03:14 PM
Panther G
Did you ,know that the name Hetzer was actually never used by the panzer forces. That name was used by someone completely unrelated to the units that used them. It is the Jagpanzer 38T
Old 11-25-2015, 03:28 PM
yellowshaker
yellowshaker's Avatar
You might want to try either Ludwig's, as he makes a working lower hull for the hetzer, or get in touch with Green Amphibian her eon the forums, as he also builds Hetzers. As for the half track, that will probably be a much harder conversion, especially being a resin kit.
Old 11-25-2015, 03:40 PM
Jhdumas
wow that sounds promising!!!...do you have any links for me?\
I have seen a halftrack metal frame.. some where.... don't remember where...
Old 11-25-2015, 08:09 PM
Airbrushler
Airbrushler's Avatar
Scalehobbyist has this looks like it might be metal frame
https://www.scalehobbyist.com/catago...p?kw=halftrack
Old 11-26-2015, 02:26 AM
Cruiser133
Cruiser133's Avatar
NOT for the faint of heart. I bought a Juckenburg E-100 kit and it has been sitting for quite some time as frankly it frustrated me after about 50hrs or so work. I have a working suspension, but I will probably turn this into a STuG/Jagd type to simplify the process. The resin parts while good, are hardly square which leads to a host of fitment issues. Everything I have done prior has been a piece of cake compared to this. Good Luck!
Old 11-26-2015, 07:44 AM
Jhdumas
Check these out.. some of you veterans will no doubt know of this stuff, but I am still relatively new.. and and searching what is available...so maybe the sdkfz 251 D would fit on one of these.. if not.. if I can get a hold of one of these metal prime mover chassis,,I'll do an AA version....
any thoughts on where ~I can get this stuff?
ID:	2132585   Click image for larger version
ID:	2132586   Click image for larger version
ID:	2132587   Click image for larger version
ID:	2132588   Click image for larger version
ID:	2132589   Click image for larger version
ID:	2132590   Click image for larger version
ID:	2132591   Click image for larger version
ID:	2132593   Click image for larger version
ID:	2132594   Click image for larger version
Name:	Screen Shot 2015-11-26 at 10.06.10 AM.png
ID:	2132595   Click image for larger version
Name:	Screen Shot 2015-11-26 at 10.07.13 AM.png
ID:	2132596   Click image for larger version
Name:	Screen Shot 2015-11-26 at 10.08.05 AM.png
ID:	2132597   Click image for larger version
Name:	Screen Shot 2015-11-26 at 10.08.40 AM.png
ID:	2132598   Click image for larger version
Name:	Screen Shot 2015-11-26 at 10.11.13 AM.png
ID:	2132599   Click image for larger version
Name:	Screen Shot 2015-11-26 at 10.11.31 AM.png
Name:	Screen Shot 2015-11-26 at 10.11.41 AM.png
ID:	2132601   Click image for larger version
Name:	Screen Shot 2015-11-26 at 10.12.10 AM.png
ID:	2132602   Click image for larger version
Name:	Screen Shot 2015-11-26 at 10.14.53 AM.png
ID:	2132603   Click image for larger version
Name:	Screen Shot 2015-11-26 at 10.15.47 AM.png
ID:	2132604   Click image for larger version
Old 11-26-2015, 11:22 PM
borealis
borealis's Avatar
Check Ludwig's site, you wil find lots of interesting and inspiring stuff...
http://www.ludwigs-hobby-seite.de/flohmarkt.html
Old 11-27-2015, 05:43 AM
Jhdumas
Awsome... Thank you!!!
Old 11-27-2015, 08:35 AM
Jhdumas
So apparently nearly all of what I asked for is available... Ludwig is a Great lead.. and I thank you for that Borealis... Green amphibian is also a possibility... Thank You Yellowshaker....I reached out to both and am awaiting responses.... also Asiatam has the functioning Famo and along with Christian at Juckenburg, he is getting me numbers on that to go
with his Famo 88 top... this morning I have been trying to track down a 1/16 Pak 40 kit from Scale-line in the Neatherlands... well that is proving really hard tp do... I think they are no longer in Business.... all contact info goes nowhere... so if any one has one that they want to get rid of,,, Here I am.... also any ideas as to where can find the Scale-line people
(the owners name was Ton?)
Just want to thank you all for the help and advice..... it helped alot, If any one is interested I'll keep you posted
Joe
Name:	Screen Shot 2015-11-27 at 10.57.51 AM.png
Old 11-27-2015, 09:48 AM
Panzerpaul
Panzerpaul's Avatar
Hi... I took up the same challenge you are facing. Here is the title to my post which should give you a lot of the basics. And yes, the guys are right.....its a lot of work. 1/16th HETZER RC Full Function Panzerpaul
Old 11-27-2015, 10:02 AM
Jhdumas
Thanks Panzerpaul... I just had contact with Ludwig.. apparently Jukenburg chassis's are not able to fit with his stuff... the Sdkfz 251,,,is another bust... I am in line with everybody else waiting for Asiatam to finally make one... I have Christian sorting our a Famo combination of his Famo 88 and the Asiatam chassis and running gear...
For the Hetzer I might end up suffering through a skratch built chassis... it'll move.. maybe fire, but no suspension??? As for the Pak 80... that is also proving to be difficult... I had a near 30 year break in my participation in this field and although much has gotten better, somethings' never change!!!! maybe it's my choices of projects..
Nothing is easy...
Old 11-27-2015, 11:10 AM
MAUS45
MAUS45's Avatar
Jhdumas, you really need to look at Chris Ludwigs Hetzer kit and parts at this link. I am going to use this fro my Hetzer build. It looks to be an easy build.
http://www.ludwigs-hobby-seite.de/Hetzer.html
Old 11-27-2015, 11:18 AM
Jhdumas
Thanx Maus45... I'm on it....I already purchased the Juckenburg kit so.. I'll be getting Ludwig's Sprockets, Idlers, Return Rollers... maybe the road wheels and the metal tracjs as well as the motor and gears.... gotta squeeze it into the Juckenberg kit...
So what do you think... road wheels and suspension?..... what am I missing... are you also starting with a Juckenburg kit? Joe
Old 11-27-2015, 11:51 AM
MAUS45
MAUS45's Avatar
I was going to use a Blue Star resin kit, but when Chris posted his Hetzer kit in plastic, I had to reconsider. I will use some of the detail from the Blue Star, but the basic Hetzer and running gear will be the stuff from Chris. Suspension, Drive Sprockets, Idlers, track tensioning parts. May use his metal wheels as well. I want to be able to run it and not worry about it falling apart. I already have the Ludwig Panther A upper hull and it is strong once you glue all the panels together. The Hetzer should be the same. Rudy
Old 11-27-2015, 12:13 PM
Jhdumas
Yeah I like the idea of using his suspension and running wheels also... still not sure how it will work... I might need to place a metal liner inside the plastic chassis....to have something to fasten things to...
I probably should have used the Blue Stay kit... but I have purchased many kits from Chris... and his hull plastic is thick... What he lacks in detail is easily fixed... just worried about getting it all in there...
What motors and gears will you be using?
Old 11-27-2015, 12:34 PM
MAUS45
MAUS45's Avatar
I may use the gear boxes Chris has on his site. The only thing that would be better is if the mid/lows from Eric would fit. That would leave more room for the mini servos for the gun elevation/traverse and recoil? It could get awfully crampt inside there???
Old 11-27-2015, 01:13 PM
Jhdumas
yes it's looking like it..
So I'm doing it... its 410 Euros for the complete thing minus the hull and top....
ID:	2132769   Click image for larger version
Name:	Screen Shot 2015-11-25 at 5.57.39 PM.png
Old 11-27-2015, 08:29 PM
Green Amphibian
Green Amphibian's Avatar
The mid/low gearboxes from Taigen are what I use in my Hetzers and they work great. I did not get any request for information about the Hetzers I make yet. how did you send your request?
Herman
Old 11-28-2015, 06:42 AM
Panther G
Looks to me that these projects are going to cost a fortune with the added risk of several different makers parts not being compatible with others.
Hard way to go but it has been done.
Old 11-28-2015, 07:29 AM
Jhdumas
Dig that!
Old 11-28-2015, 09:58 AM
Jhdumas
WOW!!! Did you guys see the upcoming Churchill from Ludwig? I'm kind of blown away!
OW!!!
Name:	Churchill tank (5).jpg
ID:	2132905   Click image for larger version
Name:	Churchill tank (6).jpg
ID:	2132906   Click image for larger version
Name:	Churchill tank (8).jpg
ID:	2132907   Click image for larger version
Name:	Churchill tank (11).jpg
ID:	2132908   Click image for larger version
Name:	Churchill tank (13).jpg
Old 11-28-2015, 11:14 AM
Martellus
yeah, he has a thread he keeps his progress in:
http://www.rcuniverse.com/forum/rc-t...ll-1-16-a.html
