Nexus ECU problem
Nexus ECU problem
Hi there!
I'm having a fight with my Gaspar fadec for my Nexus. It's been set up by the book, I've done the "Transmitter adjust" a hundred times, but it don't seem to work.
As I push Up arrow on my GSU I can read that the pulse is 982 with stick and trim down, and 2082 with stick and trim up. Just as it says in the manual. As I move my throttle stick up, the percentage also increases along with the stick. Everything is just as it should. H
The problem: With my trim down, the GSU says "Trim low", I push the trim upwards, like I've always done, it says "Ready". As I move my stick to start the turbine, the GSU says "Sticklo!" This happened after a season checkup, it has never happened before.
What should I try?
Regards
Jan Fredrik
http://www.JetsOfBergen.no
What should I try?
Regards
Jan Fredrik
RE: Nexus ECU problem
ORIGINAL: johnny84
The problem: With my trim down, the GSU says ''Trim low'', I push the trim upwards, like I've always done, it says ''Ready''. As I move my stick to start the turbine, the GSU says ''Sticklo!'' This happended after a season checkup, it has never happened before.
What should I try?
Regards
Jan Fredrik
What should I try?
Regards
Jan Fredrik
I'm also quite sure that the ECU works fine, but somewhere there is an interference, as I can't do a start procedure. The settings in the radio haven't been touched since I last ran it.
