Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
reg seyup please help
Old 11-24-2007, 09:42 AM
SJS
My Feedback: (16)
Default reg seyup please help
I am building a 35% yak and I have most of my equiptment. I plan on using 2 rec's with 2- 7.4v 4400 m/a li-ion batts for redundency. I plan on splitting the load between the 2 rec's as follos; rec 1 has 1- 5925 servo)throttle), 2 - 5955 servos (left ail)and 1 - 8711 servo(left elev). The other rec has 4 - 5955 (rt ail and rudder)servos and 1 - 8711 servo(rt elev). The aileron servos will be programmed for center woth the hitec programmer. I also have a 7.4v 2200 li-ion bat for the igniton for a da100. Will your standard regs w/ failsafe provide enough amperage for each receiver, based on my setup? Also, which reg for the ignition?
SJS
Old 11-24-2007, 01:50 PM
rrritchey
Default RE: reg seyup please help
Hi SJS,
The Standard Adj Regulators will work just fine in this application. We have flown 35% planes on a single regulator. The Ignition Reg should work for your ignition.
Please let me know if you have any other questions.
Old 11-27-2007, 07:00 PM
hooker53
My Feedback: (106)
SJS, That sounds like a good set-up your planning. All you need now is a power expander. After you first use one, you will never fly a 30% or larger without one!! Good luck. Hooker53
