RC Trimaran build
RC Trimaran build
HI to all.Can anyone give a hand of help to find some information about these beauty:
I can't find ANYTHING abot it!.Any detail weel be great.Manny Thanks.
P.S.:don't send me to google!!!.
ON, CANADA
RE: RC Trimaran build
Back in the late 1960's Chrysler built some similar boats. They had a deep center hull, with 2 shallow hulls to the outside - they called it a "hydro-vee" hull. My dad had one when I was a teenager. It didn't really go fast enough to notice any improved handling, it may have made a difference...?
Here's a pic of the type of boat:
I've seen these pictures before and I think they are somewhat stylised renderings of an Italian three pointer from the sixties. There was a series of experimental high speed racing/record boats placing the sponsons aft. John Cobb's Crusader was pretty close to that configuration.
I believe I've seen somthing like it from Australia as a small high speed car ferry with a water jet in each pontoon/sponson.
ORIGINAL: bijou
You could try the forum(s) of:
www.boatdesign.net
There are the BIG boat designers and builders.
Both sail- and motorboats.
Also plenty of rendering experts.
Just check it out.
Idealist
ON, CANADA
I came across this
http://www.youtube.com/watch?v=6uE3J...eature=related
at 31 seconds it shows the bottom and looks like your picture in first post
HI.THANK YOU so much .I tray to open the adress but sais:there are NOrights to distribuite in my country"?!!!.( tranlation is not verry accurate but You now what I trayng to say).I don't understand way?.
It´s because of copyright violation of some kind.
I have the same problem here at Vienna.
Can´t watch that video. Damn.
Would have been interesting for me.
http://www.youtube.com/watch?v=VgQSfW2-05g Check this out .... A Canard hull .............
ON, CANADA
ORIGINAL: bijou
HI.THANK YOU so much .I tray to open the adress but sais:there are NO rights to distribuite in my country''?!!!.( tranlation is not verry accurate but You now what I trayng to say).I don't understand way?.
I know how frustrating it can be when stuff is blocked from Canadian IP addresses, so I hope this helps.
@bijou
Problem:
When I try to look at it, is says in my country SONY denys the video to be played due to copyrights. Therefore it can only be because of the music used.
Solution:
If someone is able to re-place the video in there WITHOUT the music, we might be able to watch it as well.
And I´m not into illegal stuff like downloading music with copyright violation.
Laws need to be kept up.
Suggestion:
Just have a look around and check, if you find somebody who is willing and able to do that for you ( for us).
Idealist
Problem:
Solution:
Suggestion:
Idealist
ORIGINAL: Stinger9d9
The video is only a slideshow of still images, so here is the image at 0:31 into the video that eboat was talking about.
ORIGINAL: bijou
HI.THANK YOU so much .I tray to open the adress but sais:there are NOrights to distribuite in my country''?!!!.( tranlation is not verry accurate but You now what I trayng to say).I don't understand way?.
Thank you ALL very much for the help.
REGARDS
"This video contains content from Sony Music Entertainment, who has blocked it in your country on copyright grounds" these is what I get when I tray to open that adress:
http://www.youtube.com/watch?v=6uE3Jyk1fco&feature=related
That pic in the post from Stinger9d9 is of a Wallypower 118 but it's not a trimaran. The things on the sides are actually airintakes for the 3 gasturbines
http://www.wally.com/jumpch.asp?idCh...r=0&attivo=2-7
Idealist - I just said that the boat in the pic in stinger9d9 was a wally and that it wasn't a trimaran.
If you read bijous answer to stinger9d9s post you will notice that he actually asked about the name of that boat.
But maybe I just mixed it all up. Let bijou decide if my post helped him or not and if it didn't I am truly sorry for that.
HI.Guys,guys PLEASE don't become nusty!
@joccee...
"That pic in the post from Stinger9d9 is of a Wallypower 118 but it's not a trimaran. The things on the sides are actually airintakes for the 3 gasturbines" :you are right!,is not exactly what i am looking for,but we are closing;
@eboat :when I search for "La Dolce Vita" there is only about the italian movie,and bla,bla,bla.!
So from the beganing:
1) the boat from my pictures cuold be REAL or NOT(maybe is guest a computer schatch!)
2) regarding these situation can anyone make some plans,(detaliet) for internal structure!.
I intended to BUILD these boat from scratch WITH your help,but I don't have and I don't now how to use AUTOCAD to make 3D representation of it!.Let's supose we are a TEAM of naval architects and some of you cam with an ideea to build these beauty,OK?.
Can you help me with it?.
All the best until next time,my friends.
@joccee...
