50 inch Apache
50 inch Apache
Hi, I've been offered an unused 50" Apache hull/deck/cockpit with no hardware at all, and would prefer a FE setup over gas/nitro.
would also prefer a twin setup over single, purely for symmetry on the transom (central rudder between stingers). I dont need blistering speed, anything over 40 is good enough. need advice about what total power to look for (watts), what kv rating to go for to use a 5 or 6 cell setup, and what prop size. since i want counter-rotating props, please also point me to a good supplier for props and shafts. I'm on a budget so probably turnigy stuff. thanks.
RE: 50 inch Apache
I've just realised i have a new, unused turnigy t600, 880kv motor which was destined for a ducted fan plane project, but I've now stopped flying. so I'm thinking of ordering a second one for this project. can anyone indicate prop size for a 6 or 8 cell setup?
RE: 50 inch Apache
ORIGINAL: chrispoulton
Mart
[youtube]http://www.youtube.com/watch?v=6g5ZfT-bQ70&list=FLBvMrXd-byRavNCBWuCxqHg&index=29[/youtube]
RE: 50 inch Apache
thanks Mart, any idea what prop size and number of blades i should be looking at? what about shaft diameter? sorry about all the qeustions but i am totally new to electric boats.
RE: 50 inch Apache
You def best going with 1/4" flex but stepped down to 3/16" for more prop options,i can find out what size props he used but im thinking they were around 57 mm 2 blade but 3 bladers would work well also.
Mart
Mart
