ESC for Feiago 6s?
ESC for Feiago 6s?
I searched for like 30 minutes and couldnt find the amp ratings for a feiago 6s so, I cant find an appropriate ESC for it? Simple aint it?
RE: ESC for Feiago 6s?
for a 6S it will pull around 120 amps with a decent prop.
you can get away with a 80 amp esc if you run like a 12 MM prop
my 5S will pull about 140 amps.
the hydra 120 will do just fine . it has a burst rating and the motor will not draw 120 amps cont. that is it's burt rating.
if yuo water cool everything you will be just peachy
ahh.. I thought that was its continous amps but if it was I think we'd have problems all across the board, no? Thanks for the info. Now on to a decent cheap (yeah i know they dont go together) futaba RX since I killed mine, i dont know how.. I have a 2phka TX that I like so I want to use that, I figure same receiver and crystal in all of my units = one TX profit?
