Micro coupler
CA
Micro coupler
Hey all, Im am in need of a coupler that will work with a Mystery outrunner. The shaft dia. is 2.3 mm. I plan to connect it to a .125 flex cable. I have had no luck in finding one. Any iedas? Any one have one they could part with?
Thank you
Joe
Thank you
Joe
CA
RE: Micro coupler
Yeah it does seem kind of odd. The .125 flex shaft was the origional set up. I got the Mystery motor later, it just happens to have a 2.3mm shaft. I will probably rethink the set up, but would still like a coupler to fit this motor.
Cheers
Joe
Cheers
Joe
RE: Micro coupler
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_2053wt_1024
Should work, cheap too. I used two a while ago.
CA
RE: Micro coupler
Jeff, Yes I would like one or two. Let me double check the size and I will get back to you. I will e-mail your store.
Joe.
Joe.
RE: Micro coupler
That is fine...I already have the bits. Nothing odd about that shaft but if you are going to power it up I wuold consider 130 cable. That is what I have made most of. 098 cable may be ok of you keep smaller props.
CA
RE: Micro coupler
Hey Jeff; I sent an e-mail to [email protected]. Not sure if that is the correct address. I would like 2 couplers at 2.3mm (motor shaft) by .130 (Flex shaft). Let me know the price, I may only get one. Not to be cheap buy baby is on the way! You can PM me here.
Joe
Joe
RE: Micro coupler
Joe, I did not get anything...it have gone to spam. How many do you want? I will invoice you thru paypal if you give me your e-mail address.
CA
