replacement rudder
replacement rudder
Hey guys I'am trying to find a replacement rudder for the used sprint cat I bought.The one on there has a standoff bracket of 2 3/4 in. and the length of the blade is 4 3/4in. with dual water pick ups. The blade is about even with the prop now.I can't find a stand off that size so how far back do you think would be good? The boat has a quick draw motor in it and seems to turn well but the blade is held in with just a screw no bushings so it binds under load.
thanks z
thanks z
