clutch question
VA
clutch question
can i mount a clutch on the aeromarine Avenger. if so what would be the best clutch to get, there isn't a lot of room but this boat is new to me so i'm not sure. Thanks
RE: clutch question
let me no how u get on iam also building one with a clutch either a bonzi half clutch or the full one and was wondering the same thing
TN
RE: clutch question
I don't think you can do it without butchering the cowl. Check into a marine specialties clutch. I saw a guy on here who put one into an Expresscraft T-bolt cat and it was REAL tight but he did it. User name was Izvagius. you can probably find the thread if you search.
Hope it helps.
Hope it helps.
My Feedback: (63)
TX
RE: clutch question
Hey guys, I have an AM Avenger 44 that I just put a MS clutch in. It is the orginal version with the drop down where the flex is so clearance wasn't bad. I will get some pics and shoot them over. It will be a little slower than my Pro but it is more for fun. 62mph isn't always fun. I would be happy with low 50's with clutch. Catch yall later.
RE: clutch question
i fit a bonzi zen 26 with mild mod and clutch and mounts it fits verry snug without moving the engine forward or butchering the lid but the shaft moves a little more to the rear of the boat and will get in the way of a radio box unless u make one to fit around the shaft so iam not using a radio box just using my top secret servo mounts to the stringers and the base of the boat for the steering servo however the receiver will be in a water tight box alone
