Duplicating or "copying" an existing hull...ETHICALLY!
#277
RE: Duplicating an existing hull...ETHICALLY!
Come on Scott now that you have pulled boats without PVA is it not so much easier. I have found working mostly with epoxy that the PVA sometimes act as a bond and since I only use release wax removing parts is a dream. The mould just has to run in but once it is their parts nearly fall out the mould.
Cobus
Cobus
#278
DE
ORIGINAL: Hesco Racing
Cobus
Cobus
Oh yeah.....haven't touched any of my plastic mold wedges either since I stopped the PVA. The finishes have been perfect, no dust spots whatsoever. As I posted in another thread somewhere the finished part should be "customer ready" direct from the mold. Any more work you have to put into it as far as polishing, or even wetsanded first then polished is only the result of a bad mold preparation and little effort or care for a good finish. As you've seen in earlier pictures, these molds are glass smooth with a mirror finish. The product of hours of detail wetsanding and proper polishing and sealing techniques. This results with the parts pulled from them to be the same. PVA would only create more work for me in the end. No way going back to that stuff for releasing a part from a mold.
Still use it for repairs on models and full scale boats. It's the only way to assure the gel will harden properly on an already finished hull. An application of PVA following a gelcoat layer on the outside of a hull will seal the air out and make it harden nicely with out being gummy or sticky.
