KYOSHO JET STREAM GP 10
RI
hi everyone i just got a jet stream gp10 on e-bay..boat is in great shape extra motor and other parts, can anyone tell me about this boat? like when it was build. ect was it a dag or did it go ok thanks mark.. will post pics if anyone is interested
RE: KYOSHO JET STREAM GP 10
Well, if you're happy with 15 mph then it's a great boat. Not really much you can do to make it any faster. Good entry level fun boat.
JD
JD
RI
15 mph? wow what a dog,, i plan to go to the pond today,, cripes i have a cheep ele thats faster than that, lol. i have a 15 to put in it but would have to mod the pull starter not sure if i wanna do that. it is kinda a big boat for a 10 31 inches,, well its someting to play with. iam comverting the ele to nitro and also have a dumas 31 inch.. well there all winter projects keeps me off the streets lol...
MI
I've got a Jetstream 800. It's about 13 years old. Last year I stripped out the old 500 motor and gear box, went with a Direct drive 750 and motor mount from Offshoreelectrics and got about 25 out of it with 12 cells and a new ECS from Victory. Both motor and ECS were water cooled I also added new spin fins to keep it straight and no spin out in the curves. Been looking at this hull for about three weeks now and think I'm converting it to Nitro. Lots of room to work and feel with support ribbing and some new fibergrass lining this might be a perfect conversion. The boat has good clean lines. Oh BTW get rid of the streerable rudder, the U joints really can't take much punishment from more power, went through one after a couple of runs and there about $25.00 (I think thats what I paid) I'm going to cut out the old shaft and re-do the strut housing and go out through the transom to a good hardward set-up with flex shaft. One thing I do know, it will run allot longer on nitro than 12 cells, only get about 4 minute runtime and then charge for 30 minutes, while I watch the rest of the guys run Gas and nitro all day long. Hey if the price is right, have a ball with it.
WI
My buddy had the jetstream with the .10 in it... it is actually a fun little boat... but in no way was it ever built/mean for performance.
RI
i got rid of the 10 and installed a 15 and got rid of that silly gear reduction,, but the pond is frozen now and cant really test and tune it, i also just got a NITRO VEE,,doing some mods to it as well, to me half the fun is working on them, also have a dumas glass 31 inch deep vee and a hpi .25 big block going in it.. should go well that motor makes 2.5 hp. also have a 41 inch glass deep vee,not sure what motor to get for that one
IL
i've also got one of these boats, not sure what model number it is though. its got a gs 11 engine in it. i've got a brand new os .15 cv-x max layin around and wanna mount it in the jetstream. any tips?
RI
does it still have that silly gear reduction? if so scroll up a few and see what i did,,i got rid of the .10 installed a 15 asnd got rid of that silly gears,, they rob so much power...
IL
im just looking for the U joint or the 2 pieces with the 2 prongs to conect the crank to the shaft that goes to the prop, might just use the U joint idea, what u joint is that from? size etc..
any idea of what size the shaft is or know where i can find props that will fit the kyosho shaft?
thanks
Sean
thanks
Sean
IL
chyea thank you, lastnight i tore everything down, cut m shaft about 6inchs and turns out, i deen a u joint or coupler, the notch in the shaft is all it takes, i added a grub screw to the nut off the engine though, i'll post some pics
IL
OS CVX max mounted
beat up outdrive
all the god dang wholes i had to fill, still needs to be sanded and topped off. ppl who put this thing together rivited the engine mount to the hull..***?!
moved exhaust exit to opposite side
shot form the bow
thats how it sits as of right now. im getting some bass or balso wood today and am gonna make up my radio tray,
also gonna pick up a new fuel tank and new fuel lines.
i'll update as much as possible
beat up outdrive
shot form the bow
RI
your getting there.. get some 3/16 brass tubing, you can make a adapter for the prop to install a 3/16 prop. your gonna need a bigger one, like a x440 i am gonna try the stock prop then install the x440 and see the diff..get some dupli color paint and paint the inner hull its nitro prof.i did mine with white..also get maybe a 6 oz airplane tank the bigger moror will eat fuel. i installed mine infront of the motor,,look for a header off of a niteo 4 tec, and use a differ muffler,, look on e-bay you can get them cheep// the pic thats in a few post back was a t-max fuel tank,, that was to little as well. also make sure you glass the mounts you made,, i epoxy them, wasent strone the one on the same side as the pill start came loose.. so i glassed it with some fiberglass strips and resen.. to me half the fun is working on there and figuring thinks out//http://www.offshoreelectrics.com/MainPage.htm.. thats where i got the idea to do the adapter for the prop, many tips there..awsome place,,one thing to think about tho you may want a marine motor iam useing a aquacraft 15 from a hammer.. you also can get them cheep on e-bay.. keep us posted on how its going...
IL
alright, im gonna hold off on the glassing and such. theres alot of epoxy on there i think i'll be fine. any links to a more variety of props i can use? i am gonna use the 3/16" brass rod mod. i just have to find the rod first. i've had no luck at all finding 4mm inside diameter props. so im being force dto do the 3/16" rod, which is fine
here are pics of my radio tray, almost finished. need to mount it and mount my receiver also.
RI
get a 3/16 brass tube,, k&s stock #1147, it will fit right over the 4mm shaft and a 3/16 prop will fit just cut http://www.offshoreelectrics.com/MainPage.htmt
