Stiffer Stick Centering Springs TTX 650
TX
I ordered some "stronger" centering springs from Radio South. Are these something I can install myself? Any tips, tricks, suggestions if I try?
Thank you.
TP
AMA 59376
Thank you.
TP
AMA 59376
We have deleted the discussion here because this is not an open forum per RCU rules. ONLY Tactic support people are permitted to answer peoples' questions. Discussions must take place in the Radios forum, and not the manufacturers' support forums.
Regarding the stick springs, we don't have a recommendation for using anything other than the stock springs. Stronger/stiffer springs are not available as Tactic parts, and the gimbal assemblies have not been tested with stronger-than-stock springs.
TX
Thanks again.
TP
AMA 59376
TX
The "full disassembly" remark did the trick in that it caused me to remove the gimbal from the tx shell. Once that got done it was pretty easy to replace the lower spring holder and the original equipment spring. Everything is back to hunk-dory and all thoughts of increasing the stick tension have been set aside.
I must add that I am extremely happy with the TTX 650 and the TR 624 receivers which, to me, represent some of the best values in the industry, especially since they are backed by Hobbico. Name brand full range receivers @ 2/$30 - nobody even ties that! I've got a hangar full of 'em.
Again, many thanks.
TP
AMA 59376
Again, many thanks.
TP
AMA 59376
