Help with my tgm-01 Mad Bison truck
IL
RE: Help with my tgm-01 Mad Bison truck
Over time and use, the brake pads wear down and since the brakes can only travel so far the braking power weakens. To bring the braking power back up, you either need brake shims to take up the excess play or new pads if they are work too badly. The manual can tell you the smallest size it can be before needing replacement.
Surpisingly, Tamiya still carries quite a few parts for it.
http://www.tamiyausa.com/product/ite...oduct-id=44025
