Every thing you need to know about the mgt
I'm convinced the 8.0 is nothing more than a re-worked airplane engine. Look how tall the block is compared to any regular nitro car engine. Whats with the big crankcase and widely spaced mounting lugs?
I thought when I pulled the head I would find a small piston with a long stroke, but holy smokes, that piston is HUGE!!! I didn't check the stroke but it must be awful short to equal .50 cu. in.
Yeah, I've had it with the 8.0[:'(]!
Seems like bad fuel. Bought another gallon ($40[:@]) and now everthing runs great!
Put the 8.0 back in and I love it! Now what do I do with 3/4 gal. of bad fuel?
I suppose the 1/2 gal. of airplane fuel is shot too.
Just dropped a modded picco p3 .28 in to my MGT. Problem after 3/4 of a gallon when shifting from 1<sup>st</sup> to 2<sup>nd</sup> I get what appears to be torque steer a hard veer to the right and have to let off the throttle some to correct. Any suggestions on how to correct this?
8.0 transmission shift point is about 12-15ft
49t spur & slipper from 8.0 (Slipper all the way tight)
15t clutch bell
Shimmed diffs front 7k, rear 3k fluid
Pro-Line 40 series beadlocs with Bigjoes
Should I loosen the slipper and or shorten the shift point and not let the engine spool up before engaging 2<sup>nd</sup>?
thanx, matt
