Hobbistar 60 - from one aileron servo to two
This is one of several modifications to my trusty Hobbistar 60 planned for this winter... see also Stuffing a DLE 20 into a Hobbistar 60. In addition, I'll be converting the wing from rubber bands to bolt-on. That'll be documented in a future thread.
Here's the stock arrangement with the Hobbistar ailerons.
As you can see in the first picture, one of the L-bends slipped out of the servo arm. At the time I modified the linkages but stuck with the single servo.
It was suggested to me that the plane would benefit from dual aileron servos. That seems reasonable to me - more strength, plus the ability to mix in flaperons and aileron differential. The other day I checked my own stock and made a trip to my LHS to pick up the remaining stuff I needed.
Next step was to find a location for the servo as close to the centre of the aileron as possible.
Take a deep breath, and... cut.
Framing for the servo is a fairly simple affair with plywood (salvaged from an orange crate) and basswood. I did some measuring and cut my pieces to length. Here's the first section complete.
Next, I will add a longitudinal brace and cover the lateral one with sheeting so that the servo will sit level. I will have to splice some extra length into the servo wires but I've done that before:
http://www.grosbeakrc.ca/tutorials/splice.html
Hi,
I also put dual ailerons servos and bolts tohold the wing on my Hobbistar because I didn't like like the way it was. (i followed the instructions from this website to do it http://www.modelaircraft.org/mag/ftg...22/22main.html ).
Then later, I converted it as a taildragger and used the "Dubro Super Strength Landing Gear" which gave me more space between the propeller and the ground.
I still enjoy to flying it from time to time, especially during winter with skis on it. It's a very nice and stable trainer.
Good luck!
Good luck!
Hi,
Good luck!
Good luck!
Nice to know someone else enjoys this plane. Thanks for the link - I'll be saving that!
This one has also been converted to a tail dragger, and has had an extensive wing rebuild after I stuffed it in tree early in 2012. I too enjoy my Hobbistar on skis.
Now that the servo framing is complete it's time to determine the required servo lead lengths. I prefer spliced extensions to connectors where possible, so I starting by tying some string to the stock lead and fishing it through the wing.
Propping the wing on the saddle, I could determine what length was needed. I will plug short extensions into the receiver and connect the aileron servos to those rather than plugging and unplugging directly to / from the receiver every time I go flying.
A mark on the string to show the required length.
A little more time on the project tonight.
My first task was to cut the servo wire. I like to cut in the middle just in case there are any problems - lots of wire left to work with on both sides.
Next step was to separate the individual servo wires. I use my fingernails - less chance of nicking the wire.
Sliding some heat shrink onto the splice. A big one to bundle all of the wires, and a small one for each splice.
The colours of the splice match JR and the servos are Futaba - the colours are as follows.
Futaba
White - signal
Red - positive
Black - negative
JR
Orange - signal
Red - positive
Brown - negative
I follow the colour scheme when I'm splicing - makes for less confusion.
Next step - pick a wire from the splice braid and pin it in my shop-made splicing clamp with its corresponding servo wire. It's my habit to start with the negative.
With the wires touching and my soldering station set to 700º F, all it takes is a bit of solder on the tip and a brief contact with the wires to get a nice splice.
That done, I slid the heat shrink over the splice and shrunk it with the heat gun.
Futaba
White - signal
Red - positive
Black - negative
JR
Orange - signal
Red - positive
Brown - negative
I followed that with the positive and the signal wires, then shrunk the large tube over the bundle of splices. Nice and neat. One set down, three to go.
The servo end followed in the same manner. Once that was done I hooked it to my servo tester and verified the connections. All good.
Next, I unboxed the new servo and tested it out before cutting the wire. Same procedure as the first, followed by a test of both with the extensions I'll be using. All good to go.
Servos complete and set aside, I turned my attention to the wings. First thing that occurred to me was that the longitudinal brace would need a piece of sheeting on top to bring it flush with the surrounding area for covering.
After the glued cured, I grabbed my covering iron and made sure the covering around the patch was all ironed down.
A little heat followed to tighten everything up.
Next step was to cut a patch. I had a piece just about the right size to do both wings.
Slide on the clevis and we're go for solder.
Soldering takes two hands so I didn't get any photos of the process, but here's the narrative. I turned my soldering station up to eleven (900º F) and held the tip to the push rod behind the clevis. When the flux started to sizzle I applied the solder to the portion of rod inside the clevis and let it flow into the clevis. Makes a good solid joint.
I connected the push rod. At this point I had another ruh roh moment - are we seeing a pattern here? I held up the two wings, ailerons together. Looks like I put the servo bays against different ribs!
