Burnin' titain 12T motor
I have a Stampede XL-5 about 8 months old.It ruined my first motor in 3 months(may be that was my fault cuz I accidentally put a drop of glue in it)and recently it ruined its second motor(it is 5 months old) while runing suddenly it died when I picked up the car I touched tho motor it was so hot that it burnt my finger.My father says that it happened because the gearing was inappropriate I should lower it but I do not agree Ifeel that it happened because of my mistake.What I did was as soon as the charger beeped indicating full charge(i have the stock 8.4V 7cell batt. which i charged at 4 amps)I plugged it to the ESC(the batt. was still warm) and started runnin and after some time the motor died n the esc had become warmer than normal.
So,had this happened because of my fault or was it the gearing?
Please help
Please help
RE: Burnin' titain 12T motor
The stock battery combined with the stock gearing kills the motor fast. Chances are if you ran a 6 cell pack your gearing would be fine. I would invest in a aftermarket motor. A 15-17 turn motor will be just as fast or faster than the stock titan. The Trinity speed gems and Team Orion method motors are a good replacement.
AB, CANADA
run it with rustler(older) gearing i got 17 /68 spur. i burned my motor in 5 runs on 7 cell 5000 elites with stock gearing switched over to 17/68barley gets warm
If I get the trinity or the orion motor will it be fine with the stock gearing?
will it fit directly or with some mods?
IS it xl-5 compatible?
ORIGINAL: aftermarket
Sounds like gearing or even gear mesh. Where were you running? Tires? Gearing?
i run it mostly on leveled gravel which has a few bumps
