KMP B-25 CONSTRUCTION.
#552
RE: KMP B-25 CONSTRUCTION.
ORIGINAL: roltech
I have intentions of installing them, but where to order them, I heard that it take forever to receive them. do you know what they cost? and if there is a good place to order? I rely don't want to wait for too long.
Thanks for your reply.
roltech
ORIGINAL: kahloq
The RCV engines are good. There is no reason not to use them if you want.
roltech
This is main page of hobby shop regarding RCV engines:
http://www.blackflyaero.ca/BlackFly%...RCV%20page.htm
This is link to price list in Canadian Dollars:
http://www.blackflyaero.ca/Web%20Ret...ice%20List.htm
RCV 91CD : price 269 canadian
You can buy them direct from KMP as already mentioned.
You can also buy them from shopatron:
http://www.shopatron.com/index/147
#554
ORIGINAL: ivancant
Hello fellow B-25ers,
Has anyone used OS .70 4-strokes on your plane?
Myself, I'd do something a little more intensive and put Saito FA-90TS flat twins in each nacelle. Can you imagine the sweet purr from that setup?? A little bit more weight though then a standard 90 size 4-stroke, but not too much...but also a lot more expensive .
A found a site that showed a Wing Manufacturing B-25 being built with saito FA-90TS engines and that kit has 84" wingspan. I dont care for kits of that nature though, so the KMP would be my choice
#556
My Feedback: (13)
IA
Well I haven't test flown my B-25 yet and because of an accident I had two weeks ago, with a propeller on the plane....spend the better half of the afternoon,putting it together(at the field),running engines,checking everything out and then we were ready for the test flight...My buddy started the left engine,and then he was attempting to start the right one, and I was reaching across to assist him when it happen....My left hand engaged a 14" prop,and got it three times before it stopped..Anyway, had 35 stitches in it (index finger), and hopefully, tomorrow they come out..Still pretty sore....Probably another two weeks before I do some serious flying and am sure I can give a more positive report on the test flights...Am very confident the "Ruptured Duck" will fly...End of story............
#557
ORIGINAL: AKondor
HI guys:
We are also going to put out a set of pilots for the B-25. We're working on two pilots and a gunner for the front of the plane. We should have them ready in about 4 weeks.
Cheers[8D],
HI guys:
Cheers[8D],
Any word on that crew yet?
Ken
#558
MB, CANADA
ORIGINAL: hedgehog
Andrew
Ken
ORIGINAL: AKondor
HI guys:
Cheers[8D],
HI guys:
Cheers[8D],
Andrew
Ken
I'll need those too!
roltech
#560
My Feedback: (204)
OK Guys, I maidened my KMP B-25 this past Sunday, all I can say is WOW! Super smooth flyer gentle landings, 2 OS 91 4c really provided unlimited power, and they weren't even broken in. Go for the better retracts, it's worth it. At 18 lbs this bird is a performer, can't wait to fly her again.
#562
ORIGINAL: danrc2
what is the web site for the kmp b-25???
http://www.kmp.ca/
#563
MB, CANADA
ORIGINAL: airega1
What are the better retracts?
roltech
#564
My Feedback: (13)
IA
Hey, She do fly..after the first two flights, with a 'Nasty" left turn in it .finally got it to fly straight and level....the problem was ,I glued the rudders on with "Left" in them..resolved the problem by moving the stab LE (Looking at it from the rear) !/8" to the left, and adding a washer to the engines for more right thrust,...flys great....have to get my landings a little better..not going to use 'Full" flaps until on final..Tried them on the cross wind before final and it was a handful to handle..did manage to get it down in one piece...the 2 91- 4 strokes are enough power to fly the plane...beleive it can fly it with 2/3's throttle ..will try it next time out...Funny,but I believe the 'Ruptured Duck", is smiling.....am one happy camper..will post some pics later...
#565
guys
i have a different problem here
kmp is unable to ship the b25 robart gear to us in india for certain reasons
was just wondering has any body used the wing mfg b25 set on the kmp b25 or shall i go with 630 (mains ) and 639 (nose)
will appreciate a reply
thnx
puneet
thnx
puneet
#567
ORIGINAL: DUBROW
DID ANYONE DO THIS B-25 IN ELECTRIC IF SO WHERE DID YOU MOUNT THE BATTERIES?
As far as where to mount the batteries, the plane is large enough to put the battiers anywhere. For weight in relation to how glow motors would be set up , you could put them right behind the brushless motor along with the esc's...this way they get plenty of air for cooling.
I dont think the cost is a positive aspect on this size of plane with electrics. Mind you, I have a lot of electric planes(including a smaller FSK B-25 48inch wingspan and a B-17 78" wingspan with four Power 10's). The battery cost alone for the B-17 I have is $400(5 x Thunder Power 2100 3cell)
#570
ORIGINAL: Jimmy Bananas
Here are a couple of pics of the B-25.....3 flights on it..putting it to bed for the winter..will fly it again next year....
#572
My Feedback: (13)
IA
KAHLOG:
No , not that cold in Iowa..still some good flying weather left...have some other planes I want to fly,so just going to weather it this winter and fly it next year..Using Mag 91 4-strokes...that is enough power for the plane..can fly at 2/3 throttle with no problems...the gas engines you mention,would be to heavy...if you were to build a 100"-110" ws B-25,then i say gas engines would be OK..alot of tail weight would have to be added, if used on the KMP B-25...going to try to add a few more pics if I don't screw up...
#573
MB, CANADA
ORIGINAL: TLH101
I just recently added a few panel lines to mine, and some good beefy landing gear.
What retracts are you using? I also want to change mine to a better quality.
roltech
#574
NE
Here are some pics from this season. The bomb drop is a real crowd pleaser. Love the way this plane flys. Saito 100s, spring air retracts, weighs in at 21.8 with full bomb load.
#575
My Feedback: (90)
ORIGINAL: roltech
roltech
ORIGINAL: TLH101
roltech
