KMP P-38
My Feedback: (19)
IL
KMP P-38
Here is my KMP P38. Two Zenoah 20 EI motors, stock retracts with Robart struts. Graphics by Die-Hard Graphics. They are something I came up with and are not scale. I have 1 flight on the plane and as is the case with most I have seen I ran out of down elevator trim. No flaps were used and you could tell it was 22lbs. I really like the bird and was impressed with the quality of the build.
My Feedback: (19)
IL
RE: KMP P-38
All JR Servos. 821 on the elevator, JR Sports on the ailerons, flaps, rudders, throttles and gear with an 8101 on the nose gear. I am using fromeco 2400's on the ignitions and a 4800 on the receiver.
AB, CANADA
RE: KMP P-38
Are the engines happy with the 2 cell lipo, or do you have a regulator?? The instructions don't really say if a bit more voltage will be bad for the ignition module.......
