Walkera New 2403 TX
Walkera New 2403 TX
A small update from Walkera for their 2402 tx. As the 2402 is a very basic tx without any adjustment. The new 2403tx feature large backlight LCD, digital trim, 2.4Ghz, etc. With new feature D/R switch and throttle limit. D/R limit the servo travel to 50% for more stable flight. And the throttle limit limit the throttle to 30-80%. These two features are very good for beginner as it make the helicopter very stable. Once used to the control of the heli the pilot can switch back to normal mode for faster response. The first heli feature this radio is the CB180Z, combine with the 45 degree rotor design and RX2437S receiver with flight stabilization system. Make this very stable heli even easier for beginner to enjoy.
RE: Walkera New 2403 TX
Nice. Good idea on their part. I think if they add some programmability to the TX would be nice too. They have buttons for it, but they don't really use them for anything. They could have added some things like exponential and maybe a throttle curve setting feature.
ORIGINAL: dchin62973
They should just make this the standard 2.4 GHz digital 4-Channel Tx.
[8D]
[8D]
The antenna on the receiver is about 10" long! I've never seen a 2.4g receiver with such a long antenna on it.
On the down side... there is a push button that is directly under the throttle/rudder stick. That's the "Power Down" button. It's there so you can work on adjusting your esc's .. and you push that button when you do a range check.
BUT, if you are flying and accidentally toggle that button, the Guai goes insane. That button should have been on top of the Tx.
