Wildhare Ultimate Build Thread - Finished & Flown
#351
My Feedback: (178)
NC
RE: Wildhare Ultimate Build Thread
I am not an expert, but I have built a few planes, and I must say that this plane (I'm reoutfitting a used airframe) is a hunk. I'm sure some of the newer models have improvements...ie...more airfoiled surfaces, a hatch on top of the fuse...etc. Anyway, changing what I had stated in the previous post, I used Y connectors to connect each side of the wing servos, then hooked up one side to the aileron channel, other to the flap channel....works great and allows for lots of adjustments.......now I have to figure out how to set this plane up for very stable flight, not into 3D at all.....any ideas or suggestions appreciated....Thanks WC
#352
WC.
Make the cg fall on the ink marks on the blue tape I left on the top wing for you. The cg location is also written in the owners manual that came with the plane. You may need to use the hatch at the rear bottom of the plane for the batteries, I did with the DL50 in the plane and a 1300mah nicad on the motor box.
Balance the plane inverted..it is actually easier than upright.
Any more questions, I will be happy to help you.
John
John
#353
My Feedback: (46)
LA
Is anyone still flying these? I had one that had been in a box for a couple of years whilst I got caught up on business and just finished building it. Slung a DA50 on the front, all Hitec servos and carbon main gear. Can't find the canopy so I'll just go without one. Got it balanced yesterday and will maiden it the first time the weather permits. Anyone know why they were discontinued? Seems like it will be a fun little plane to fly.
#354
My Wild Hare Edge 540T is now 6 years old and over 3000 flights with a FPE 52cc and it is just an unbelievable plane.
#355
My Feedback: (98)
He had 50 made, my friend and I got 49 & 50. Tom at WH said Bipes are a on and off thing with guys, they're kind of out of fashion now. I love the way mine flies, my friend flew his twice and wants to sell his, he's a pattern flier, I just throw the plane around. My canopy got a crack in it so I asked if Tom had one, he does for $45, I used an Extra's canopy I had laying around, a little heat and it fit just fine.
#358
TX
I may have some wheel pants. To the best of my recollection we never had a plane that was solid white on the bottom, maybe somebody re-covered it.
TF
TF
#361
HI
Vert stab had big gaps that I had to fill with balsa and gorilla glue to fill. I had to use covering to cover the gap because it looked so bad.
The vert stab had to be cut and adjusted to I can get a decent hinge line for the rudder,
The elevators had to be cut since they did not fit on the H stab in the fuse.
The H stab is not cut/built right, so it was hard to get it to look and be straight in the fuse.
The lower wing fits loose in the fuse and gaps everywhere, and the gaps are not even straight.
To get the wing straight on the fuse I had to modify to mounting holes and blind nuts.
that's where I'm at, basically every step Ive come across Ive had to take a step back and take hours to figure out the best way to fix it.
I've built two hanger 9 airplanes and three aeroworks airplanes, this one is definitely the most challenging.
