ZDZ 80 Rail mount?
AL
ZDZ 80 Rail mount?
Need to know if there is a mount to convert
ZDZ 80 to an rail mount?
Have a Pica P-40 1/5 scale...motor will be inverted..
Kit does not have an applicable firewall mount. Only has 2 longitudinal braces from 14" back in fuse..
Tony
Tony
ZDZ 80 Rail mount?
Sounds to me like this would be an easy application to create a firewall. You'll be able to mount the engine to this firewall and leave the back entirely open for the carb. A little thought and enginuity and I bet you make this work quite well.
