20tooth pinion on rc18t?
RE: 20tooth pinion on rc18t?
High speed runs only, and you may need to give it a push start.[&:]
If you start and stop too many times with that gearing, you may stress the electronics.
I run 26t pinion, 55t spur, 4900kv motor, and 3s lipo...
not exactly the standard motor or esc though.
just do it, the sooner you kill it, the sooner you can upgrade!
