mini revo new springs, riding too low in rear
I am upgrading my revo in parts so i went out and about the black and tan springs, put tan on front and black on rear. also added 60wt fluid to each shock but now my rear seems to be riding pretty low
do i need higher wt fluid? or is something else wrong
i was riding with two batteries for awhile but still ran on one and it was still riding pretty low in the rear
My Feedback: (12)
OR
RE: mini revo new springs, riding too low in rear
They all seem to ride low in the rear. Even after I upgraded the shocks. So I installed front rockers in the rear to help out.
ORIGINAL: gforce2448
Banned
have you threaded the springs up very much ? the black springs are a little bit shorter then the green ones so I had to thread mine nearly all the way up to stop it sagging. We were mainly jumping so if you want better handling you might not want them so tight. I'll include a pic so you see what I mean
ORIGINAL: TheKennyKiller
Banned
well you might want to get the GPM shocks ... they are very stiff, I will only be using mine for bashing ... I would also recommend getting some alloy shock mounts
what wt oil you using?
Banned
I have some alloy rockers coming in the post and I missed a delivery today so they are probably at the post office right now. In my traxxas shocks I have 70wt all round and in my GPMs I have 40wt front and 70wt rear. I have some 60wt and 80wt on order so when I get them I will play around with them and see what works best. Not sure if the brand matters but I am using Muchmore Racing shock oil
Banned
none really but they look cool and will be stronger not that the stock rockers are weak... one thing I don't like about the stock ones is each time I unscrew them I feel like I am wearing away the thread and one of the screws had a little bit of plastic stuck to it when I first took it out so I am hoping the alloy rockers have a stronger thread ... btw I didn't get my rockers today
My Feedback: (12)
OR
I would highly recommend the RPM knuckles. I first had a set of HR aluminum ones but the inserts wore out and they had as much slop as the stock carriers. Got a RPM set after that and haven't had any problems.
Banned
ORIGINAL: imp3r10
ill stick with regular rocker arms
should i get rpm knuckles or aluminum?
BC, CANADA
Anyone know of any Youtube video's that walk you through any mod's.
I'v got the 1/16 e-Revo. So far out of the box it's awesome, Not sure how or what I would mod yet.
ORIGINAL: Pinboxer
i know squirrel from TheToyz has a youtube account and it posts some videos of modding it
Banned
ORIGINAL: Pinboxer
BC, CANADA
Thanks.
If your looking for a place to start the suspension a-arms and axle carries are a good place... I would recommend RPM because they make the best stuff and unlike many brands they come with very good instructions so as long as you read and follow them carefully you will be fine.
ORIGINAL: Pinboxer
I got a used revo some weeks ago. It had the castle 4600kv + sv2 esc, but for now Im running the stock motor/esc.
So far I have the rpm arm + knuckles front, and the wide a arms from traxxas + rpm knuckles back.
the gtr shocks
and alu push rods
I have on order :
alloy shock mounts
thetoyz Delrin Rear Chassis Brace
gpm Alu Knuckles for front
gpm alu rockers + bb
alu center drive line
and I will get the alu bulkheads later.
That should cover the most I think.
Hmm, I just had a look at the order from the toyz again, and I have managed to order the summit rockers, dæng.
the gtr shocks
and alu push rods
I have on order :
alloy shock mounts
