rc18t2 brushless ESC problems, green light blinking
I was jsut using it a couple of days ago, and now when I turn it on, the esc lights up like normal, and then the green led light just blinks very rapidly. At this point, I can use the steering, but not the throttle. If i pull the throttle on the transmitter, it simply does nothing, but if I turn the wheel on the transmitter, it will turn the servo.
RE: rc18t2 brushless ESC problems, green light blinking
Try to reprogram the ESC:
Follow the steps in that chart on the first page:
http://teamassociated.com/pdf/cars_a...dyMicroESC.pdf
I have the exact same Proble with a sc though it has the same esc. I did reprogram it and it worked but it keeps doing it. Sometime I can just disconnect the battery and reconnect and that will work. Pretty screwy. I bought a truggy at the same tIme and there are no issues with that one.
