Official Mini-T Thread
#1951
RE: Official Mini-T Thread
ORIGINAL: rcmaster123
you would lose alot of runtime though
ORIGINAL: Damz
I have read that tekin motors and mamba motors (b/l) are much the same.. Its the esc that makes the difference! So yeah, you mamba should be fine w/ the tekin motor..
The 380 would be insane! And it SHOULD fit, I was just looking at my mini-t imagining another 4mm all the way around, and I THINK it will work....
Let us know how u get on
my vendetta has a 380 motor (stock but now have a brushless 380)
and i get regular runtimes as a mini-t and rc18 on a 370
#1952
NH, NEW ZEALAND
ORIGINAL: walkingcarpet
why would the runtime be lost?
ORIGINAL: Damz
#1953
well im pretty sure that there will not be a significant difference between a 380 and 280 in consumption of power
also considering that my 380 motor is a 3900kv and mambas range from 4600-8000
i mean i get 30minute runtimes with my vendetta st
which is maybe 2 times the weight of a mini-t stock
just running 6cell nimh but i still get speeds of around 30mph
oh well
i probably just stick with the stock motor
than maybe a mamba 4600 or 5700 (do they make a 5700)
oh well
#1954
MI
Carpet ..... You can use the mamba with the tekins and use your vendetta motor in the mini t i have both and i switch the motors and esc all the time as well as the battery packs. Tekin 8000kv and a 3900kv Hyperion the Tekin screams in the mini t and in the vendetta just with a little cog and the hyperion is just sooo much power it makes it fun.
#1955
so you CAN run a 28mm can motor in the mini-t correct
such as my greatplanes 28-35 3900kv ammo motor?
it has a 3.2mm shaft that takes standard 1/10th pinions
what pinions fit the mini-t?
ya i can imagine that the ammo motor
will be an overkill on the mini-t's tranny
since it has SO much power
#1956
I run the mamba 6800lv in my mini-t and dont understand why theres any need bigger motor, unless your doing speed runs up and down the street which is stupid
#1960
NH, NEW ZEALAND
ORIGINAL: Deftones123
#1962
Hi, I don't know what those wheels are but RMP make nice nylon wheels in Chrome, black and white. I prefer the black or white (which you can dye) as the chrome is prone to chipping - apparently.
[link=http://www.liquidrc.com/index.php?main_page=index&manufacturers_id=54&sort=20a&filter_id=147&alpha_filter_id=0]RMP wheels[/link]
Cheers,
Neil
Cheers,
Neil
#1964
NH, NEW ZEALAND
ORIGINAL: neiloid
chrome is prone to chipping - apprently.
Couldnt be more true!
Iv only put one pack through my RC18T, on my new premounted Losi smashers, and the chrome is already chipping off.. Not cool!
.....Unless your a carpet racer.....
#1966
Hi,
Just wondering what CVDs you are using? I carefully made a set of MIP, but they left drive side keep popping out of the outdrive from the ball diff - which is a real pain, so I'm back to using the dog bones it came with. Any CVDs out there with the same length as the OEM dog bones to prevent this happening?
Thanks in advance.
Neil
Thanks in advance.
Neil
#1969
is it nessacary to upgrade to the dual slipper if im running a mamba? and does it do anything else for my mini t besides allowing the drive train to slip when hit by a hard shock?
#1970
NH, NEW ZEALAND
I dont run a dual slipper with my tekin b/l.. And we all know tekin is far more powerful than mamba... Lol watch the debate start over that one...!!
I use the stock slipper!
#1974
ORIGINAL: neiloid
Cheers,
Neil
Cheers,
Neil
#1975
would u reccomend upgrading to it, if I have a hard impact(crash) with my stock slipper would it damage my mamba motor at all or would the dual prevent damage to the motor from impacts
