i broke my mini-t
CA
i broke my mini-t
i just mounted my new shocks and i went to drive it and i went to drive it and i didnt drive it more than 10 feet and broke it. i went off a jump and it landed on the left rear wheel strait up and down. it snaped it right apart. it sucks. i didnt even get to test out the shocks. does anyone know the part number for this part and how much it would cost to fix. i need aluminum ones wish someone made them.
RE: i broke my mini-t
Looks like: LOSB1027 Spindle, Carrier and Hub set.
If it is the black plastic piece that broke. You get both the front and rear in the kit. Comes in handy! Replaced both several times.
It should cost $4.00. www.stormerhobbies.com has them in stock.
Hope this helps!
AWSUM9
Hope this helps!
AWSUM9
CA
thanks alot awsume9. i only need the rear because i got aluminum ones in the front. i geuss i could sell the front ones on ebay.for real cheap.
CA
well i broke one of the front knuckles puting my new teamlosi oil shocks on and well theres only one knuckle and the two C brackets that hold the knuckle and i need the extra rear hub. so i was thinking if somone needed them at my fart (far away race track) its called Hot Rod Hobbies does anyone here race there. hay i just noticed my abreiviation says fart.
i cartwheel mine alot jump down whole flights o stairs and whatnot and mine(still box stock) never broke a thing even full bore off my jump into my 1/10 cyl head with the rf a arm didnt break anything mine has landed this jump and barrel rolled clean across the room(12ft is big when u are a 1/18 scale 1/10 stadium truck lol) heavy towing full bore into brick walls cartwheels barrel rolls ass plants nose dives none of it broke a thing
CA
i think because i had those stiff oil shocks on it that it didnt give any so instead of the shock going up it just snaped the hub. the shocks were prety stiff. i had to drop it from like 2 feet in the air before they would even budge.
CA
i got some losi oil shocks last tuesday. and are perfact and im not useing those tuoring shocks anymore. as posted in "Mymini mini-t track" thanks though. i did put the lightest springs on them when i had them on the car. but never charnged the oil witch i should of. because i had like 50 wt oil in them but now it all gravy.
