OK EXPLAIN TO ME PLZ
I got my both cars ready mini t and rc18t ready for brushless, now i want flat out the best set up with batteries and motor, , can some one tell me can i run brushless mottor with stock bats for now, or do i need good ones right away,
what should i get / and need
mottor
bats
conectors and and chargers and so on
im new to alectrick and i want to learn. THANKS IN ADVANCE!
mottor
bats
WA
RE: OK EXPLAIN TO ME PLZ
assuming you are using a BL system (which includes the esc that comes with it) and not just the motor, you can use NimH batts such as GP1100s or Kans/CBP 1050s.
if you plan to use just a BL motor, with your own non-BL esc, AND lipos, then you'll need to use a "low-voltage" cutoff device such as [link=https://www.fmadirect.com/site/fma.htm?body=detail&item=1897§ion=2]this device[/link] from fmadirect.com.
[8D]
[8D]
WA
a 3 cell, but I recommend only 2. as I ve told others before, with the 8000kV mamba, you'd be lucky to use 50% of its potential and even if you did use more, in a micro, it'll be doing backflips, somersaults and tripping before you could get all that power down from the wheels to the ground. PLUS, you'll definately need to beef up your drivetrain.
alternatively, another BL system you may want to consider - Tekin is coming out with there scorpion, is spring. www.teamtekin.com [8D]
here's [link=http://www.yourmicro.com/forums/showthread.php?s=&threadid=15215]more info[/link] on the Scorpion.
WA
ORIGINAL: jakjr
Brushless motors can not be used with a non brushless ESC.
ok whats cogging , besides that cogging thing that scorpion sounds good! if only it was here now and i didnt need my rctnt running NOW i would prolly wait
WA
cogging can occur on all "unsensored" BL systems. In layman terms, it's when you accelerate from either a standstill situation or moving situation (like out of a corner or straight away), the motor sputters or stalls momentarily.
its was a major problem with the earlier mambas. CC has corrected it (somewhat), but imo, there are still issues with them. Its recommended that you purchase the optional phx usb link with the system, (IMO, it should be included with the system.), otherwise you could end up sending it back for replacement.
here's more reading, for your research.
[link=http://www.one18th.com/forums/showthread.php?t=15366]link 2[/link]
[link=http://www.one18th.com/forums/showthread.php?t=14617]link 2[/link]
there's alot more, but I think this will suffice, for now...
wow thanks for the info so in other words mamba sucks becouse of cogging[:@] damit how long are the run times with lipos
WA
djeurofoeva,
I wouldnt use that term so loosely. CC has a great reputation (from what Ive read and heard) for servicing the cogging problems that arise. What I am saying is your chances of getting a "cogging" unit are high. And many users have justified satisfaction with the mamba by way of CC's customer service to correct their problems or by way of having to purchase the option phx-usb link to correct the problem. If you read the user manual, or any of the advertisements, it states clearly that the phx-usb link is supposed to allow the end-user to "custom tailor" your driving needs/requirements. This is definately NOT the case. IMO, it is being mis-represented and is strictly being used as a tool (that the end-user must BUY), to fix a known problem (ie. the cog issue). If you DONT buy it, and your mamba cogs, then you will have to send it in for a replacement as you cant solve the problem by using only your Tx to program it. Talk to any of the users and they can only set it to one, maybe 2, different "custom settings" for "minimal cogging or no cogging" - any other settings and your mamba will cog. Yes, there are users that have had no cogging at all regardless of the packs they use (good or cheap), the gauge of wire or connectors, etc, but then there are also many users that have gone the full 10 yards with good packs, gauge of wire, deans, etc. and they still cog.
As for lipos, runtimes are definately higher compared to NiMh packs based on similar driving habits.
Just so that you know, the 8000kV will have shorter run times than say the 6800kV or 5400kV. The tradeoff is 8000kV is insanely fast - but then how much power can you really use? and how long will your drivetrain last?
wide_open247,
The maximum charge rate for Lithium Polymer (lipos) cells is 1C. [8D]
wide_open247,
ok so i have a lot of factors to consider before buying these set ups and its alot more than i expected , i always thought you drop in and play this is alot more complicated than i ever expected i should realy do my homework before investing , is there a bruchless system to mach the cc bl that does not have this bogging thing?
Well i am using a mamba 8000 on gp1100's with the CC Esc and latest software, my cogging is all but gone, it only does it occasionally now, hardly noticeable
My Feedback: (-1)
you will have so much less work to do to the motor with a brushless. no more new brushes to buy. dont have to worry about stuff getting in them. dont let the idea of cogging scare you away from brushless.
WA
ORIGINAL: djeurofoeva
As for cogging, only time (and regular users) will tell if its cogless or not. When reviews of the CC Mamba came out, they all touted the mamba was very good, all positive in their reviews....well...you know what happend (don't believe everything you hear or read). Do the research and testing yourself, as I did, before you decide. Same applies for the Tekin Scorpion BL - imo, I'd wait for other users to poll their findings rather than "sponsored" users (slightly biased, imo).
WA
ok is there bruched motors that can do the same and isnt there other bl companies that make non cogging motors?
he's a member on yourmicro and one18th and knows his motors very well. he sells tehm on $bay under the username of "iamachickenduck".
currently, he's sold out, but should have more next week.
you can checkout his posts on both those forums and the comments he's received from (independant) users.
WA
ORIGINAL: rustler08
"...dont let cogging scare you away from brushless..."
My comments are merely what Ive experienced and tested. As an Engineer, its "in my blood" to play devil's advocate.
That's why I suggest being patient and lets see how the new kid (or should I say old kid, but new start) does.
im gonna get castle comp x motor for now and when the scorpion comes out im gonna get that too, and wich ever one is better that will go in my rc18t and the crapier one is gonna go to my minit. lol so cogging is not a such a big deal,
I called castle creations to talk to them and get their opinion on the cogging , The responce was if you should get a bad motor set, we will take care of you but they say they solved the coging problem, and now the bls are smooth and dont need insanly good bats to able to run without cogging. i think some of it was bs what he told me but i still want to go with it and see for my self, i dont know about the usb thing tho the guy sayd its for helping out and making things fasterand easier, instead of being required or needed in order to run cog free when i asked him.
WA
Im glad you've decided. [8D]
imo, the phx usb link will provide you with better/easier ability to work out any issues you may possibly have with the mamba. I would advise you to read thru the user manual carefully before hand, so you know 'exactly' what you'll be doing to program the unit. Many users have commented about how you have to listen to the beeps and watch the leds, etc... to understand what's being programmed. Its available to view on their website.
