Motor Help for the Mini Quake!!
CA
i'm getting a mini quake and I don't know what motor to get for it... which would you reccommend? lmk thanks... i don't want to go spend $130 on a mamba either.... right now i have the stock motor with 2c lipos... lmk thanks
WI
RE: Motor Help for the Mini Quake!!
i dont think the mamba works right now until they make a smaller pinion,
but a realy good moter designed for the mini queake is the t-rex, off of one18th.com, it has lots of power and is 400 sized, dyno tuned. more
go check it out at www.one18th.com and go to shoping or someting like that
WI
the mamba doesnt put out enough power with the stock gearing so it coggs( stutters under acellertion)
that is a very decent moter and i can find out if it can handle lipos
CA
the stock motor your mean? it does handle lipos, the guy that sold it to me is running the lipos in it right now.... do you have a link to where i can get the t-rex or stega? jw thanks are there ANY other motors availible? jw..... thanks
WI
[link=http://shop.one18th.com/product_info.php?cPath=39_55&products_id=495]heres the moter, the stega is cheaper but lacks in power, you can buy it right there. there are other moters avalible now if you do a serch on it[/link]
ORIGINAL: RabidRacer
