Which cheap charger?
AZ
what is the best cheap-o peak charger that i can get that will charge an RC18T in or under 1 hour an that comes with the special cord that chrages mini's (hope you know what i mean by that). please help asap. im picking it up tomorrow.
RE: Which cheap charger?
i think the black widow charger is good. the blue one. there is 6 diff. amps u can charge it at . and its about 50 bucks. hope this helped a lil.
My Feedback: (-1)
http://www.horizonhobby.com/Shop/ByC...rodID=LOSB1206
good one, it will charge ur battery in under an hour. granted you will need to change the connector. but that won't be so hard
AZ
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCLD5&P=ML]will this one charge it? and do i have to buy a seprate connector?[/link]
I use that one, it works great. It's also nice because it's AC/DC, so if you're out somewhere you can just clamp it onto your car battery and charge there.
Yes, you do need to buy a connector. Couple bucks.
AZ
ORIGINAL: gerwen
AZ
ORIGINAL: rustler08
i don't think it willl work.
It will and does work. I charge my reedy gp1100 pack with it just fine. I also charge my transmitter (8 cell nimh) and my nitro rx pack with it too. It's a great charger for the price.
WA
I just bought a Dynamite Vision Peak 2 AC/DC charger and it is pretty darn nice. Can charge 4-7 cells at 1,2,4 amp. Its peak and trickle and you can moniter how far it has charged by the LED meters. 40 bucks is a nice deal for it too.
SD
I use the MRC959 charger. Works great and can set the charge rate from .5 to 4.5 amps. It charges 1-8 cells so it will charge your radio batteries too. It costs about 40-45 bucks.
